Shock swap out |
Shock swap out |
swood |
Nov 29 2004, 01:21 AM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
I've got an old set of Koni reds and 140# springs for the rear, but since the front will be still on 4x4 status, what can I cheaply do to ditch the stock shocks and drop it down a bit?
Anyone have some decent aftermarket shocks to part with? This is just a temporary set up until I go for the full suspension modification. (IMG:style_emoticons/default/wink.gif) |
Jeroen |
Nov 29 2004, 05:35 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
maybe I misunderstood your Q, but you can lower the front by just turning the torsionbar adjusters
swood |
Nov 30 2004, 01:00 AM
Hmmmm...not sure what your refering to.
Attached image(s) |
Mike D. |
Nov 30 2004, 02:28 AM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
#17 in the diagram - do you have a front sway bar?
put some KYB's in the front for now, they're stiff and cheep. With stock boges in the front and koni + 140s in the rear the car is going to oversteer, I think... (IMG:style_emoticons/default/unsure.gif) - someone else confime this maybe... -Mike D. |
Lo-Fi Version | Time is now: 17th June 2024 - 01:02 AM |
