> Fiberglass rocker cover question
r_towle
post Jun 7 2013, 06:50 PM
Custom Member
I got the rocker covers with my flares.
They have a 1/8 inch indentation where the jack point cover would go, with the idea that you cut that out when you install them.
I have removed my jack point due to rust and I don't want to put them back to just start the process all over again.
So, how can I make this indentation smooth with the outside face and eliminate the risk of it popping out or cracking?
Replies(1 - 2)
Mike Bellis
post Jun 7 2013, 07:08 PM
Resident Electrician
The can says "Kitty Hair" around here. FLAPS or any plastic shop will have some. Maybe even Walmart.
I would scuff the gel coat off the rocker first. I would also add some fiberglass gel to the kitty hair mix. It helps it flow better and fill voids. Then just sand smooth and finish with spot putty.
rick 918-S
post Jun 7 2013, 07:23 PM
Hey nice rack! -Celette
Here's what I would do. Grind the jell coat, either use a fibreglas reinforced filler or mix up some glas resin and mat it in. Grind it, fill it and sand it like anything else.
- Lo-Fi Version Time is now: 12th March 2026 - 06:52 PM
