| Harpo |
Jun 9 2013, 12:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
For the record I did use the search option and was unsuccessful searching
What can I use to clean up my terminals for the electrical connections in my 914? Somewhere I had read something about dielectric grease but I'm thinking I need to clean the terminals first. Thanks for your help David |
| Cap'n Krusty |
Jun 9 2013, 12:59 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Google "electronic contact enhancer" I use Stabilant 22 ($$$$!, available at GM dealers), but there are a lot of good ones out there.
The Cap'n |
| pcar916 |
Jun 9 2013, 01:15 PM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
I've used these for 40 years.
http://www.stanleysupplyservices.com/jonar...rnishers/g/8172 Still have the original one. Mine has diamond strips with different grits and came with ~10 strips in the handle.. Once you've cleaned chemically, then with bronze and SS brushes, then start polishing with this. Polish is a way to reduce surface area (against oxygen) and is a corrosion fighting system as well. Not the harsh file-oriented cleanup but this is where you build in further problems, assuming you're not pushing too much current through the connector. Good luck |
| DBCooper |
Jun 9 2013, 04:16 PM
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
Like the Cap'n says, that or "electrical contact cleaner", which used to be (maybe still are) carbon tetra-chloride. I've used different brands, they all seem to work, in a small can-high price.
| stugray |
Jun 9 2013, 06:28 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
This works good and you can get it at HD:
http://www.homedepot.com/p/CRC-2-26-5-oz-M...er#.UbUdExXnaP8 cleaned I recently cleaned my ground points on the car (scrub them down until you see the shiny brass under all that crap. Then I sprayed all of the parts with the contact cleaner and put it back together. Stu |
Lo-Fi Version | Time is now: 15th March 2026 - 01:08 PM |
