> Mig welding question
nomore9one4
post Jun 10 2013, 06:02 PM
Member of the Eastcoast Thread Killers Club
So I picked up a little mig welder. My beginners welder if you will.. I set it up to practice on a fender laying on the table. Hooked up the ground to the fender and when I went to weld I got a huge spark off of the ground clamp...wtf? I figured before I went any further I would check in with the experts..Anyone? I cant imagine this is normal (IMG:style_emoticons/default/dry.gif)
Replies(1 - 9)
bulitt
post Jun 10 2013, 06:23 PM
Achtzylinder
QUOTE(nomore9one4 @ Jun 10 2013, 08:02 PM) *
Did you assemble the machine? Leads hooked up to wrong polarity?
914_teener
post Jun 10 2013, 06:26 PM
QUOTE(nomore9one4 @ Jun 10 2013, 05:02 PM) *
Normal if the ground contact is dirty or not attached properly to the "work"
timothy_nd28
post Jun 10 2013, 06:28 PM
QUOTE(914_teener @ Jun 10 2013, 04:26 PM) *
nomore9one4
post Jun 10 2013, 06:34 PM
QUOTE(bulitt @ Jun 10 2013, 04:23 PM) *
It was hooked up when I bought it
nomore9one4
post Jun 10 2013, 06:35 PM
Thank you! This is probably the cause..will update now that I know my lifes not in danger (IMG:style_emoticons/default/smile.gif)
ThePaintedMan
post Jun 10 2013, 09:06 PM
If cleaning the ground to bear metal doesn't work, try to get a copy of the manual for the unit and verify that it is wired correctly. The polarity is reversed based on whether you're doing Flux-core welding or true MIG (using a gas source). Sometime there will be a diagram on the unit itself to outline how it's supposed to be setup.
Jeff Hail
post Jun 10 2013, 09:33 PM
I would go with the ground clamp first and then check the terminal inside the welder. Then check the gun supply terminals.
Reversed polarity shouldnt make it pop. I reverse the polarity with MIG all the time when welding upside down to keep my ear wax virgin.
When welding make sure you have the proper stickout so the wire doesnt burn back and stick to the tip. Make sure you are not shorting the tip out on the material.
Easy test to see if the board has a short or blown diode. Run about 5 inches of wire out and then touch the wire to the material and press the trigger. You should see the wire pre-heat and glow red if everything is ok.
If your spool is old it can get rust deposits on the wire surface. It will sputter and pop.
worn
post Jun 11 2013, 08:40 AM
QUOTE(Jeff Hail @ Jun 10 2013, 07:33 PM) *
A mig will weld on rusty metal - very badly. When the arc hits the rust you will get sparks all over, your puddle will fly around and you will be too dazzled to see what you are doing. Then when it cools the bead will be just sort of glued to rust.
So the important thing is to make sure that the ground and the weld surface are shiny new steel. That often means cutting back to clean metal making for a bigger repair. Do that - it will be worth it. Also the heat and wire feed adjustments both do things to the weld so you will need to experiment. Bigger metal needs more heat, so if you are welding something thin to something thick, always start heating the thick piece first. You may never have to directly heat the thin, the puddle will just melt into place.
Good luck. (IMG:style_emoticons/default/welder.gif)
nomore9one4
post Jun 11 2013, 03:55 PM
Thanks everyone! (IMG:style_emoticons/default/beerchug.gif)
- Lo-Fi Version Time is now: 31st July 2025 - 03:24 PM
