Oil consumption engine rebuild |
57lincolnman |
Jun 23 2013, 10:15 AM
Member Group: Members Posts: 174 Joined: 14-September 10 From: Los Angeles Member No.: 12,175 Region Association: Southern California |
I have about 500 miles on a 1.8L engine rebuild and noticed that it has burned about a quart of oil. Is this normal? I've also noticed some fine black soot on the rear bumper as well. It has Brad Penn break-in oil in it currently.
rhcb914 |
Jun 23 2013, 10:22 AM
member Group: Members Posts: 358 Joined: 3-February 04 From: Boston, MA Member No.: 1,626 |
By 500 miles I would expect the rings to have seated. You mention you are running break-in oil. Have you changed the oil in it yet? I would start there. Check in consistency and smell of the oil. Does it smell like fuel? Black soot on the bumper could also be an over rich condition which can gas wash your cylinders preventing the rings from seating properly.
57lincolnman |
Jun 23 2013, 08:05 PM
I have about 500 miles on a 1.8L engine rebuild and noticed that it has burned about a quart of oil. Is this normal? I've also noticed some fine black soot on the rear bumper as well. It has Brad Penn break-in oil in it currently. Thanks. I will change out the oil and filter tomorrow. The oil DOES have a gas smell! I have a AEM air/fuel gauge on the car. It reads between 12 and 13 so I believe it is in within an acceptable range. Thoughts? |
r_towle |
Jun 23 2013, 08:55 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Have you driven it hard enough to seat the rings properly?
57lincolnman |
Jun 23 2013, 09:05 PM
Have you driven it hard enough to seat the rings properly? Not sure what is meant by hard enough but... driven at variable speeds, some shifts @ 4200 RPM, cruising on I-75 at 80 mph. When I had it at 80 mph the oil temp reads at 230 degrees. Not great but not in the danger zone either. Otherwise, oil temps are 210-220 range. Cylinder head temps at 320. |
Lo-Fi Version | Time is now: 7th June 2024 - 07:43 PM |
