Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
Researched the topic and found a very nive thread on it but one thing it didn't address was what type of material would be best for the bolts used to plug the injection holes? Something with the same rate of expansion to aluminum I would think. Brass maybe?
nebreitling |
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 ![]() |
resuse the injector tubes themselves, but cap them off with some plumbing caps (surprisingly the same type threads)
works like a charm, and avoids the heat expansion issues. |
ws91420 |
Yes I have one a Lensley 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region ![]() |
That must be a Calif. only thing. My 76 had no air pump, egr, or cat as far as I know. When rebuilding engine no holes in head or signs of anything being plugged.
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,339 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
All 75/76 cars had air injection ports on the heads. If yours doesn't, the heads have been swapped.
scotty914 |
suby torque rules ![]() ![]() ![]() Group: Members Posts: 1,528 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 ![]() |
QUOTE(vsg914 @ Dec 2 2004, 03:56 PM) All 75/76 cars had air injection ports on the heads. If yours doesn't, the heads have been swapped. not true my 75 1.8 has no holes or smog pump. did have a cat thought |
TheCabinetmaker |
I stand corrected, forgot about the 1.8L. (IMG:style_emoticons/default/smoke.gif)
jwalters |
Sooo Close....... ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe ![]() |
(IMG:style_emoticons/default/smilie_pokal.gif) You could use those holes to put individual egt probes in and use the quad gauge that I posted a few minutes ago---would be too-cool to monitor all four cylinders at once!!!! (IMG:style_emoticons/default/beer.gif)
Lo-Fi Version | Time is now: 15th July 2025 - 03:21 AM |
