Can I put 2.0L rockers on a 1.8? |
stugray |
Jul 6 2013, 11:30 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I assume that they should fit just fine.
Stu |
stugray |
Jul 6 2013, 12:08 PM
I will clarify: I stole the 1.7/1.8 rockers from my running 1.8L to convert a 2.0L to the swivel feet.
Now can I put the 2.0L rockers on the 1.8L that I "raped" for it's rockers. Obviously I need to readjust the valves afterwards... Stu |
Dave_Darling |
Jul 6 2013, 12:44 PM
Yes, you can. Since I'm a wee bit superstitious, I would consider swapping the rocker shafts and associated bits over as well as the rocker arms. Just in case the parts have "worn in" to each other.
BTW, I believe that the 1.8 and 2.0 rocker arms are the same. Only the 1.7 rocker arms are different, and that's really only in the diameter of the adjuster. --DD |
Drums66 |
Jul 6 2013, 12:54 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
Yes, you can. BTW, I believe that the 1.8 and 2.0 rocker arms are the same. Only the 1.7 rocker arms are different, and that's really only in the diameter of the adjuster. --DD .....I've done this several times with no problem's!! (IMG:style_emoticons/default/thumb3d.gif) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) |
914Sixer |
Jul 6 2013, 04:34 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Why bother, they are the same rocker assembly UNLESS someone changed them out? 1.8 & 2.0 are 10mm adjustment screws. The 1.7 is a 8mm screw. The 1.7 rocker set up is the one to use if you are going for porsche swivel rockers.
Lo-Fi Version | Time is now: 8th June 2024 - 12:30 AM |
