Rear main seal, How to remove without a seal puller? |
Rhodes71/914 |
Dec 3 2004, 04:54 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
What's the easiest way to remove the rear main seal. I do not have a puller.
my15window |
Dec 3 2004, 05:05 PM
Member Group: Members Posts: 61 Joined: 23-March 03 From: fort collins Co. Member No.: 465 |
harbor freight has a plastic hook type puller for about 2 dollars,
jr91472 |
Dec 3 2004, 05:41 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
I used a long pry bar, but you must be careful (you know this).
Check the Tech Article on Pelican for clutch replacement. There is a section about this seal with pics. They used a screw driver and a metal bar to lay across the gap..... anyway the picture says it better and this worked for me, but it was a bitch. good luck |
Sammy |
Dec 4 2004, 07:13 PM
. Group: Members Posts: 1,190 Joined: 21-January 03 From: Orange, Ca Member No.: 178 |
I like to drill one or two very small holes in seals (around 1/16") in the middle, ie not near the inside or outside edges.
Then screw a sheet metal screw into the holes and with a pair or vice grips or something use the screw to pull the seal out. Gotta be real careful-like not to drill or screw into something important tho. |
Rhodes71/914 |
Dec 7 2004, 10:39 PM
QUOTE(Sammy @ Dec 4 2004, 05:13 PM) I like to drill one or two very small holes in seals (around 1/16") in the middle, ie not near the inside or outside edges. Then screw a sheet metal screw into the holes and with a pair or vice grips or something use the screw to pull the seal out. Gotta be real careful-like not to drill or screw into something important tho. Thanks Sam that worked great, took less than 5 min. |
Lo-Fi Version | Time is now: 5th June 2024 - 02:01 PM |
