ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,614 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
I'm wanting to reproduce the engine sheet metal in fiberglass. I know about Getty. If someone has a set we can use, we promise to get it back to you in the same condition or blasted and powder coated, if you wish. (IMG:style_emoticons/default/biggrin.gif)
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
save yourself,, buy the getty, it used to be cheap and they have doubled the price, labor , and if youre a rookie you will probably Fup the tin pulling it from the mold..then what ??
http://www.rennspd.com/P_Detail.asp?PID=373&Task=STD |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Jeff, I'd be pulling the molds. (IMG:style_emoticons/default/wink.gif)
sixnotfour |
Still a steep learning curve on 5 pieces of tin = too much work imho
or buy the fiberglass and mold from that ?? Actually I have some repo stuff from JP I would lend you and its simpler... |
ConeDodger |
Still a steep learning curve on 5 pieces of tin = too much work imho or buy the fiberglass and mold from that ?? Actually I have some repo stuff from JP I would lend you and its simpler... Mark is no fiberglass rookie. I think he might actually be at the upper end of the learning curve. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I have oem you could use. Pm me and we'll set it up. Mark
ConeDodger |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
(IMG:style_emoticons/default/poke.gif) If your Hell Bent on making the job more difficult (I invented it) then at least do a sexy Carbon Fiber lay down.
larryM |
emoze ![]() ![]() ![]() Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California ![]() ![]() |
cheap solution for you - i have a Beach Boys set of 3 of the 4 pieces (frt, sides) in FG, plus the oem tin rear piece from my oem engine - $100 cash takes it all; just stop by the next time you drive from Reno to Sacto I'm wanting to reproduce the engine sheet metal in fiberglass. I know about Getty. If someone has a set we can use, we promise to get it back to you in the same condition or blasted and powder coated, if you wish. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 06:45 AM |
