wankle914 |
I'm new here ... Group: Members Posts: 0 Joined: 20-July 13 From: mass Member No.: 16,139 Region Association: None ![]() |
Left over parts from a rebuild of a 1973 Porsche 1.7 and some 2.0 parts $75 for the lot
1.7 Parts set of standard pistons and new rings, pistons have been walnut shell blasted and checked, good wrist pins 4 cylinders, one of which has pitting too deep to remove with honing, the rest have been honed, and ridge reamed and checked, so if you have one good 1.7 cylinder you could have yourself a good set ready to install, all matching parts are numbered 1.7 Mahle main bearings without the rear ,std, (I damaged the rear by incorrrectly inserting the guide pin, but had to buy a complete set, as above if you have a rear bearing you would have a complete set) 1.7 First size over guides 7/8 are there, I didnt use these as I didnt want to bore the head, the guide ID matches a stock 1.7 valve stem 1.7 stock pushrods 2.0 Mahle Rod bearings complete 2.0 Airfilter 2.0 Fuel Computer, ( I have not tried this unit) Please call Tom from 7-9pm Eastern 508-904-8926 $75 for the lot Attached thumbnail(s) ![]() ![]() ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 17th June 2024 - 10:35 AM |
