pressure plate to flywheel bolts, What Grade are they? |
malcolm2 |
Aug 9 2013, 08:04 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I see that AA does not carry them, I don't see them on the Pelican site either. I know the size, but can't find bolts that size, except grade 8.8.
Clark |
Mike Bellis |
Aug 9 2013, 08:14 AM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Not sure the actual strength but you can get stronger ones here...
http://www.boltdepot.com/Metric_tap_bolts_...10.9_steel.aspx |
Chris H. |
Aug 9 2013, 08:24 AM
Senior Member Group: Members Posts: 4,031 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Mike I nominate you for "linkmaster general". You have the best site links.
malcolm2 |
Aug 9 2013, 08:57 AM
Not sure the actual strength but you can get stronger ones here... http://www.boltdepot.com/Metric_tap_bolts_...10.9_steel.aspx Nice, and they sell pieces vs. cases. No minimum qty either, but $6 to ship $1.2 worth of bolts. I will keep them in mind. Thanks |
cwpeden |
Aug 9 2013, 09:03 AM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
andys |
Aug 9 2013, 09:56 AM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
On that page, it clearly states pressure plate bolt, but the accompanying diagram shows a muffler bracket bolt. Thought I'd mention this so you make sure you're getting the right bolt. Andys |
malcolm2 |
Aug 9 2013, 10:25 AM
On that page, it clearly states pressure plate bolt, but the accompanying diagram shows a muffler bracket bolt. Thought I'd mention this so you make sure you're getting the right bolt. Andys You beat me to it. Click the one under that and it shows some other car's flywheel.... I would call that a fly ring. |
AE354803 |
Aug 9 2013, 10:43 AM
Member Group: Members Posts: 232 Joined: 13-August 12 From: Southern California Member No.: 14,801 Region Association: Southern California |
jaxdream |
Aug 9 2013, 12:28 PM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
I see that AA does not carry them, I don't see them on the Pelican site either. I know the size, but can't find bolts that size, except grade 8.8. Clark Clark , of all the things George has , he does have these bolts (IMG:style_emoticons/default/aktion035.gif) . Gotta look in the right sections of the catalog, I got mine form him a few years ago , also get the o-ring seal for the rear of the fltwheel as well as the washer/plate that goes under the bolts , along with the pilot bearing. They have low profile heads on them to clear the clutch disc . You get em from who ever , but AA does have them , heck use the 1-800 number ... Jack |
stugray |
Aug 9 2013, 02:05 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I'll bet they have them at Ace hardware.
Or: https://www.belmetric.com/hex-bolts-class-1...tags3pvvco5vug0 They dont need to be as strong as you would think. They are not under that much strain and it is in shear. (however I am sure someone will have a story about breaking them before). Stu |
McMark |
Aug 9 2013, 02:32 PM
Because it's a push type clutch, the bolts aren't holding much pressure. And they're not really holding any shear pressure. I don't know for sure what the spec is, but from what I see in the PET, they look like standard 8.8 bolts.
Mblizzard |
Aug 9 2013, 08:03 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Clark I have a set if you need them let me know.
Lo-Fi Version | Time is now: 3rd June 2024 - 06:28 AM |
