2.0 Injectors - different for 74 VS 75? |
lsintampa |
Aug 14 2013, 12:41 PM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
I need a working set of injectors for my 75 2.0
It was a CA car - but not sure if that matters. Searching about I'm confused. This part: W0133-1600748 is what I thought I'm looking for, but everywhere I find it, it says it is for 73-74 914 2.0 Was there a different injector for the 75 and later models? Thanks, Len |
914itis |
Aug 14 2013, 12:46 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
All 2.0 injectors are green.
Cap'n Krusty |
Aug 14 2013, 01:01 PM
All 2.0 injectors are green. Part numbers make a difference, color doesn't. As I recall, '75-'76 injectors are different. Worldpac lists the '73-'74 injectors as available, the later ones aren't, at least from them. Porsche part number 039 906 031, Bosch part number 0 280 150 019. I don't have the numbers for the later injectors. The Cap'n |
lsintampa |
Aug 14 2013, 01:05 PM
All 2.0 injectors are green. Part numbers make a difference, color doesn't. As I recall, '75-'76 injectors are different. Worldpac lists the '73-'74 injectors as available, the later ones aren't, at least from them. Porsche part number 039 906 031, Bosch part number 0 280 150 019. I don't have the numbers for the later injectors. The Cap'n So 74 2.0 injectors will or will not work in a 75 then? |
SLITS |
Aug 14 2013, 02:07 PM
All 2.0 injectors are green. Part numbers make a difference, color doesn't. As I recall, '75-'76 injectors are different. Worldpac lists the '73-'74 injectors as available, the later ones aren't, at least from them. Porsche part number 039 906 031, Bosch part number 0 280 150 019. I don't have the numbers for the later injectors. The Cap'n So 74 2.0 injectors will or will not work in a 75 then? Bosch ESI says the 0 280 150 019 (VW 039 906 031) was used on 914 2.0L from 08/72 - 12/75. So they should work. The 2.0L in the 1976 912E used 0 280 150 105 but it was L-Jet. All the bullshit aside, I took a '73 engine out of my car and replaced it with a '75. Injectors were the same and all I did was plug the air pump holes in the head. Car ran perfectly. |
JeffBowlsby |
Aug 14 2013, 05:21 PM
914 Wiring Harnesses Group: Members Posts: 8,527 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Same-same. See attached chart for specs and substitute injectors. I saw new 2.0L injectors the other day for sub$70. Just google the PN and you will be surprised what comes up.
Attached image(s) |
lsintampa |
Aug 14 2013, 05:54 PM
JeffBowlsby |
Aug 14 2013, 07:31 PM
The 031 and 031A 2.0L injectors are interchangable. Some speculate that the pintles are harder in the 031A injectors, but who knows...their specs are the same.
r_towle |
Aug 14 2013, 07:35 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Lo-Fi Version | Time is now: 3rd June 2024 - 04:31 AM |
