Relay Question:, PO made a boo boo |
BKLA |
Sep 7 2013, 04:35 PM
Really old member Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest |
While installing some new hella 500's on rennenmetal brackets, (http://www.rennenmetal.com/proddetail.asp?prod=1610) I pulled the fuse box loose to use a switched power supply for the new switch and what did I find..... a remote four prong relay wired to the relay plug in for the fog lights.
Why would someone place a remote relay in lieu of a standard round? (I assume cost and availability...) The fog lights are pilots, but I don't see why that would make a difference to the relay. (round relays were harder to find at one time, but are now available for about $27 each at pelican parts.) Before I pop in one of my round relays from my 'stash, does anyone see anything that I'm missing as to why a different relay was used? (Electrical is not one my strong points.) thanks! (yes, the yellow is 43 years of dust.) |
Mike Bellis |
Sep 7 2013, 05:09 PM
Most likely an availability problem for the PO. You should be OK to restore it.
BKLA |
Sep 7 2013, 05:17 PM
Thanks... thats what I had assumed.
But I don't know electrical.... voodoo black art to me |
914Sixer |
Sep 8 2013, 07:08 AM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
That sure was a lot of work for making a simple plug in!!!
Lo-Fi Version | Time is now: 3rd June 2024 - 12:13 AM |
