Cylinder heads for 1.8, replace, fix, or upgrade? |
Hine62 |
Sep 11 2013, 02:36 PM
Member Group: Members Posts: 132 Joined: 4-October 12 From: Binghamton, NY Member No.: 15,000 Region Association: None |
When we tuned up the valve gaps I noticed that one of my exhaust ports studs was fixed using a heli-coil. Of course that coil needed to be replace because it pulled out, then when tightening the other side of the same port I noticed the hole the stud was in was cracked, and of course it broke. I tired JB weld but that didn't work.
So my question is... can this problem be fixed, or should the heads be replaced (new or used?), or is there an upgraded head? I'm assuming the engine will need to be pulled out to take the heads off. |
Mblizzard |
Sep 11 2013, 03:21 PM
Have you looked at the Time-sert thread repair process? It has much better success than the heli-coil especially on exhaust. The insert is larger than the coil ones so depending on your extent of damage it may not be possible but it is something to look at before pulling the head.
Cap'n Krusty |
Sep 11 2013, 05:43 PM
One: Why would you ever think JB Weld would fix that? Is their advertising THAT good?
Two: A timesert fits in the same thapped hole as a Helicoil. It's NOT bigger than a Helicoil. If the boss is cracked, it's cracked, and no insert is gonna fix that. The heads will have to be welded properly, and the odds are the cracks are a LOT more numerous and extensive than you think. Three: Yes, the engine has to come out to remove the heads. A bit of advice. If you're going to have the heads welded, use a specialist shop with a LOT of T4 head experience. You could be looking at 1500-2K with parts. The Cap'n |
Mblizzard |
Sep 11 2013, 06:36 PM
Sorry Cap'n I thought the OD of the Time-sert was larger. I guess I am just remembering the shoulder cut being lager than the insert.
Hine62 |
Sep 11 2013, 07:37 PM
One: Why would you ever think JB Weld would fix that? Is their advertising THAT good? Two: A timesert fits in the same thapped hole as a Helicoil. It's NOT bigger than a Helicoil. If the boss is cracked, it's cracked, and no insert is gonna fix that. The heads will have to be welded properly, and the odds are the cracks are a LOT more numerous and extensive than you think. Three: Yes, the engine has to come out to remove the heads. A bit of advice. If you're going to have the heads welded, use a specialist shop with a LOT of T4 head experience. You could be looking at 1500-2K with parts. The Cap'n Actually I was thinking of replacing the heads with used or new. From what I've seen a set of used heads goes for around $300 and new ones around $800. Pulling the engine out and putting heads on is not a problem. My father worked on these engines back when they were still making them. Any other places to pick up new heads besides aapistons and autoatlanta? P.S. I know JB weld was a crazy idea, but I was hoping to keep driving until I put the car in storage for the winter. |
stugray |
Sep 12 2013, 10:55 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I have a set of 1.8L heads in decent condition.
If you are interested, I'll pull them out & get some inspection pics. Stu |
malcolm2 |
Sep 12 2013, 01:37 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
When I had HAM redo my heads, he would only take one, the other was really damaged from the valve seat. Anyway, he has a stock pile of used 1.8 and he re-did one of his along with my decent one.
Stu might set you right up tho. |
Cap'n Krusty |
Sep 12 2013, 01:42 PM
When I had HAM redo my heads, he would only take one, the other was really damaged from the valve seat. Anyway, he has a stock pile of used 1.8 and he re-did one of his along with my decent one. Stu might set you right up tho. That's what you get when you deal with an experienced T4 head rebuilder ................. The Cap'n |
r_towle |
Sep 12 2013, 08:52 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Www.aircooled.net has them.
400 bucks each..cheaper than fixing your. Rich |
Dave_Darling |
Sep 13 2013, 09:37 AM
Note that the new AMC heads from Spain have decent castings, but not so great hardware. The general procedure with them is to replace pretty much everything but the basic casting when using them. I don't remember if the seats and guides were part of the stuff that should be replaced, but I wouldn't be surprised if they are.
--DD |
r_towle |
Sep 13 2013, 10:46 AM
Note that the new AMC heads from Spain have decent castings, but not so great hardware. The general procedure with them is to replace pretty much everything but the basic casting when using them. I don't remember if the seats and guides were part of the stuff that should be replaced, but I wouldn't be surprised if they are. --DD Just curious. Have there been documented cases of failures of the new heads, bolted on right out of the box? Rich |
ldsgeek |
Sep 13 2013, 12:16 PM
Member Group: Members Posts: 155 Joined: 27-June 10 From: New Hampshire Member No.: 11,885 Region Association: None |
Not sure if the hardware is that bad, but I think the valves and ports are sized for the bus engine rather than the 914 version, meaning it will run but run out of steam at the top end.
Bob L. |
Sep 13 2013, 12:46 PM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
ThePaintedMan |
Sep 13 2013, 01:00 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Not sure which ones you are looking at but the prices on that page are for a pair. Not each. Too cheap?? No. Its for a pair. Read closer. QUOTE Cylinder Head, 1800cc Type 4 VW Engine, EACH, 022-101-361C Price: $399.95 Cylinder Head, 1800cc Type 4 VW Engine, EACH, 022-101-361C is a new AMC casting with stock valves and combustion chamber. This fits the 1800cc Type 4 engine, and it's nice to have these available new because the used ones are so worn out and unrebuildable. This price is per head, we recommend changing BOTH for a balanced engine. |
r_towle |
Sep 13 2013, 03:30 PM
Not sure if the hardware is that bad, but I think the valves and ports are sized for the bus engine rather than the 914 version, meaning it will run but run out of steam at the top end. 1.8 liter 914 motor uses the same valve sizes and the same heads as the 1.8 liter vw motor. The difference is in the oil dipstick location. The only motor that was different is the 2.0 liter motor and the difference was limited to the heads that Porsche put larger valve into for the 914. So, these AMC castings are bolt on replacements. I believe some engine builders and machine shops do not like the hardware used in these heads, I have heard that before. I have not heard of any failures of these heads, so it may not be the top of the line hardware, but for 400 bucks per head, its still a bargain. Many people buy these heads, remove all the hardware, and build up racing heads from these just because they are new castings...so the alloy has no heat cycles...thus it will take the abuse longer without a failure. For 400 bucks, it would cost at least that to fix a cracked head...and that does not include buying new hardware, new valves, a valve job, new guides, all of it.. Still a great deal. rich |
Dave_Darling |
Sep 13 2013, 04:02 PM
Have there been documented cases of failures of the new heads, bolted on right out of the box? I don't know. Len Hoffman was one person I recall saying that the included hardware wasn't up to snuff. He may have documented cases, or he may have simply looked at what was on the heads and decided it was unsuitable. You'd have to ask him. --DD |
r_towle |
Sep 13 2013, 04:21 PM
Have there been documented cases of failures of the new heads, bolted on right out of the box? I don't know. Len Hoffman was one person I recall saying that the included hardware wasn't up to snuff. He may have documented cases, or he may have simply looked at what was on the heads and decided it was unsuitable. You'd have to ask him. --DD Just wanted to clarify that. It's one persons opinion....however correct he may be, not arguing that point... I have not heard of any bad things... |
HAM Inc |
Sep 13 2013, 06:20 PM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
QUOTE I don't know. Len Hoffman was one person I recall saying that the included hardware wasn't up to snuff. He may have documented cases, or he may have simply looked at what was on the heads and decided it was unsuitable. You'd have to ask him. Countless documented cases. Have one in the shop right now. Intake seat fell out at 30K miles. Documented failures in order of most seen. Retainers pulled through causing valve-piston collision. Keeper grooves hammered out so bad the end of the valve failed causing valve-piston collision Seriously hammered ex seats to the point that the adjuster ran out of adjustment Wildly excessive guide wear. Broken intake valve guide. The portion that's exposed in the port. Great castings, shitty parts. |
Jake Raby |
Sep 13 2013, 07:59 PM
Note that the new AMC heads from Spain have decent castings, but not so great hardware. The general procedure with them is to replace pretty much everything but the basic casting when using them. I don't remember if the seats and guides were part of the stuff that should be replaced, but I wouldn't be surprised if they are. --DD Just curious. Have there been documented cases of failures of the new heads, bolted on right out of the box? Rich Yes, look no further than thesamba to see them. I have been bitten by them as well, having lost a retainer on a stock engine using a stock cam in a bus application. The retainers are junk and the keepers pull through them. Thats among the random deficiencies with every other aspect of their factory hardware. I don't even consider using more than just the head castings from these. |
Hine62 |
Sep 13 2013, 09:59 PM
I'm glad I started this topic... great info. I still think the AMC heads are each not per pair.
Lo-Fi Version | Time is now: 7th June 2024 - 03:38 AM |
