> Front trunk springs, Best way to get these things off?
Gint
post May 23 2003, 08:30 PM
Mike Ginter
Anybody know a quick, easy or maybe even safe way to get these things off?
(IMG:http://www.914world.com/members/ginter/MVC-218F.JPG)
Replies(1 - 19)
Aaron Cox
post May 23 2003, 08:32 PM
Professional Tinkerer
vise grips and a pair of gardening gloves....expamd spring by grabbing it w/ gloved hand.....pull it toward front of car, w/ vicegrips, pull the spring out of the slot. presto!
why are you taking them out anyway?
Gint
post May 23 2003, 08:34 PM
Mike Ginter
Yeah, I thought of that, but then I thought of how I would put it back when the car is all painted and purty and the spring is powder coated. (Hi Rusty)
Any way to do it without scarring everything up?
Aaron Cox
post May 23 2003, 08:38 PM
mine were sagging, so i moved 'em up to the front setting. no scarring whatsoever. gardening gloves so your fingers dont get pinched by the spring. the vice grips to hold the end of the spring to move it up to the next slot
Gint
post May 23 2003, 08:51 PM
Mike Ginter
When I said scarring, I meant the springs. Vice grips will bite into them and tear up the finish when reinstalling.
Jeffs9146
post May 23 2003, 09:10 PM
Ski Bum
Nothing a little bit of duct tape cant prevent! lol Gint thats way too anal! I bet that car is going to be nice when it is done!
Jeff
Gint
post May 23 2003, 09:22 PM
Mike Ginter
It just seems a shame to go to all of this work and then tear it up with vice grips.
Maybe a piece of old sail panel vinyl between the jaws of the vice grips?
madd_dogg_914
post May 23 2003, 09:39 PM
Maybe I am alone here, but I have removed the springs several times by hand. You just grab them in the middle and pull back till you clear the clip and slowly lean forward. Theoretically it is dangerous, but the springs only close in on themselves, they dont spring outward. If you did lose your grip all they would do is fall straight down. Also by grabbing in the middle the spring seperated less, so you wont get pinched skin when they compress down. Just my .02 worth. It would be a shame to damage a freshly powdercoated finish by scratcing with vise grips. This way is quick and easy!
-Chris
I am not responsible if this somehow backfires and someone dies (unless it is me) But I really don't see how this could be construed (sp) as dangerous.
Elliot_Cannon
post May 23 2003, 11:43 PM
Group: Retired Members
I made a tool kinda like the one Porsche uses. I used an old floor jack handle, drilled a hole about 6 inches from the end that inserts into the jack, bolted an "eye" bolt and hooked about a 6 inch length of chain to the "eye" bolt. Hook the chain to the spring put the end of the jack handle in the top of the shock tower and pull. Not a very good description I know but my son hasn't shown me how to put pics on line yet!
Cheers, Elliot
Brad Roberts
post May 24 2003, 12:01 AM
914 Freak!
Rope To pull them off.
Gint, your big enough to put them back on by hand...if not have a freind help you.
B
Gint
post May 24 2003, 08:06 AM
Mike Ginter
I can't seem to get a good enough grip on them with my sanding dust coated gloves. I'll give it another shot later. My main concern was getting them back on after everythings freshly painted/coated. Thanks.
rhodyguy
post May 24 2003, 08:26 AM
shackle and a coat hanger. the shackle makes for easy pulling. on reinstall the hanger gets trapped behind the spring. just cut it and get a new one. i gotta tell you mike, everytime you post a picture, the ongoing rust issues you have makes my head spin. that hood seal channel is pretty ugly.
kevin
seanery
post May 24 2003, 08:49 AM
waiting to rebuild whitey!
I did it by hand. Take off the gloves and you can get a good grip.
Joe Bob
post May 24 2003, 08:53 AM
I did the coat hanger trick....THEN replaced both front and rear with shock kits....the marine type that are stainless steel look really sharp.
Non CW, but like I care....
(IMG:style_emoticons/default/MDB2.gif)
Gint
post May 24 2003, 10:48 AM
Mike Ginter
That one might be a winner.
That's tame compared to the long and inner fender in the engine compartment. We'll get her fixed up though.
Thanks guys (IMG:style_emoticons/default/beer.gif)
Brad Roberts
post May 24 2003, 10:51 AM
914 Freak!
I have had the coat hangers come apart on me.. and send me to the ground while pulling. Make double damn sure you wrap it tight. Use a hammer turned sideways in the hanger. Better grip farther out to the sides.
B
tracks914
post May 24 2003, 01:20 PM
Canadian Member
Learn from anothers experience...prop the hood first!!! (IMG:style_emoticons/default/wacko.gif)
It could come down pretty fast. (IMG:style_emoticons/default/huh.gif)
Aaron Cox
post May 24 2003, 04:57 PM
ductape on the vise grips will do the trick for you CW's out there....but real men use their hands to pull it! (IMG:style_emoticons/default/wink.gif)
Gint
post May 24 2003, 07:28 PM
Mike Ginter
Without gloves on I pulled'em right off. That'll work.
Lawrence
post May 25 2003, 07:45 AM
Hi brother.
Good job. My arms are killing me from scraping yesterday. Thanks for the brake cleaner tip. Goof Off is good stuff, but doesn't hold a candle to brake cleaner. I bought 6 cans of 3M stuff. It was on sale.
-Rusty
- Lo-Fi Version Time is now: 24th June 2026 - 11:59 PM
