Flywheel bearing greese, What kind of Greece |
gunny |
Sep 28 2013, 09:22 AM
Member Group: Members Posts: 205 Joined: 17-October 12 From: Madison Al Member No.: 15,051 Region Association: South East States |
Instalinng a new clutch. What kind of Greece do I use for the bearing and shaft?
pcar916 |
Sep 28 2013, 10:08 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
I always use a small dab of synthetic wheel bearing grease. Just enough to work into the needles or it'll come out onto the flywheel.
gunny |
Sep 28 2013, 10:58 AM
SirAndy |
Sep 28 2013, 11:48 AM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
What kind of Greece do I use for the bearing and shaft? (IMG:http://www.914world.com/bbs2/uploads_offsite/www.lonelyplanet.com-179-1380390504.1.jpg) http://en.wikipedia.org/wiki/Grease_%28lubricant%29 (IMG:style_emoticons/default/biggrin.gif) |
Cap'n Krusty |
Sep 28 2013, 12:51 PM
I always use a small dab of synthetic wheel bearing grease. Just enough to work into the needles or it'll come out onto the flywheel. The felt ring is there to prevent the grease from flowing onto the clutch. The bearing comes pre-greased, and it's not a particularly good idea to mix different types of grease. I use the Sachs grease on the shaft and splines, and it's likely that's what they put in the bearings, too. That said, I use Kendall Super Blue grease for that application. The Cap'n |
Lo-Fi Version | Time is now: 9th June 2024 - 08:52 PM |
