e_artiles |
Member ![]() ![]() Group: Members Posts: 76 Joined: 14-February 12 From: Corona, CA Member No.: 14,131 Region Association: Southern California ![]() |
I need advice. The PO replaced the stock mirrors with Talbot racing mirrors and I want to reinstall the stock mirrors. The problem is that he drilled through the stock backing nuts in the doors to get the mounting u-bolt in! (IMG:style_emoticons/default/headbang.gif)
What would be the best way to re-mount the stock mirrors? |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,021 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
I need advice. The PO replaced the stock mirrors with Talbot racing mirrors and I want to reinstall the stock mirrors. The problem is that he drilled through the stock backing nuts in the doors to get the mounting u-bolt in! (IMG:style_emoticons/default/headbang.gif) What would be the best way to re-mount the stock mirrors? You may have to shop for longer stainless fasteners, remove the vent window and install the mirror with nuts on the backside. The vent window isn't hard to remove. Pull the trim card. there are two bolts through the door below the vent or corner window. Then remove the nut holding the vent window adjuster at the bottom of the door. Then remove the vent window adjuster from the bottom of the forward glass guide attached to the corner window. This will allow you to pull the corner window up and out of the door. You will then have a fairly clear access to the bottom of the mirror support. |
e_artiles |
Any suggestions of a source for stainless steel screws?
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,912 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
Do you have a local hardware store that has a 'Bolt Room'? If so, determine the length you need and take a stock screw in to see if they have a head that closely matches. Don't forget your nuts (IMG:style_emoticons/default/shades.gif)
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
Depending on the size of the drilled holes, you could also try to get some Rivnuts to put into the holes and then have new threads to use.
McMaster Carr is an excellent source for fasteners as well, but you have to buy larger quantities. |
jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
pic of stock bolt
Attached image(s) ![]() |
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,631 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
The stock bolt is the same as the ones used to hold the door striker plate in the door jamb.
rick 918-S |
ben*james |
LIFER ![]() ![]() ![]() Group: Members Posts: 525 Joined: 16-February 09 From: Portland Oregon Member No.: 10,062 Region Association: Pacific Northwest ![]() ![]() |
The stock bolt is the same as the ones used to hold the door striker plate in the door jamb. (IMG:style_emoticons/default/driving.gif) I love little tid bits like that! |
jfort |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,186 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest ![]() ![]() |
Garold is a wealth of knowledge. I've seen his driveway and garage. He's earned it.
e_artiles |
I don't currently have the stock mirror screws. Does anyone happen to know the diameter and thread count on those screws?
sfrenck |
Member ![]() ![]() Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region ![]() ![]() |
I found SS screws and nuts at my local Lowes - but I didn't use Metric threads (since the stock threads are destroyed, you don't have to use metric either).
Nine_14 |
Member ![]() ![]() Group: Members Posts: 311 Joined: 30-August 12 From: Germany Member No.: 14,873 Region Association: Germany ![]() |
Use cage nuts like shown in the pic.
e_artiles |
How do the cage nuts work? Do they hold on to the sheet metal?
Harpo |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None ![]() |
I believe it is M8-1.25. Bolt depot is a great source but you do have to buy in volume. Way cheaper that the hardware store
David |
Nine_14 |
dangrouche |
dangrouche ![]() ![]() ![]() Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None ![]() |
yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,455 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
What kind of shape are they in? I'm interested in a set of Talbot/Durant style mirrors.
jimkelly |
or - maybe - if you weld, buy this small section of a door and graph it in. plenty of people cutting up 914s.
are you just doing drivers door? Attached image(s) ![]() |
Lo-Fi Version | Time is now: 19th July 2025 - 03:15 AM |
