bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
Before shutting down I ran about 20 minutes with Seafoam in the gas. If that matters.
About 4000 miles since last valve adjustment. Car running great. #1,3,4 are nice gray and #2 has white soot on the stem Is this just a leaking valve due to mileage since last valve adjustment or ??? Attached thumbnail(s) ![]() ![]() |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Lean cylinder or it got most of the additives that were in the fuel.
bandjoey |
After the valves and timing I'll check the carbs. Had no popping through the carbs but ill resink to be sure its not tunning lean.
Should I spray the white stuff down with carb cleaner before putting on the exhaust or just leave it alone? Never used sea foam before. It smelled like straight alcohol. Thanks |
SLITS |
Just clean it off as best you can. Should be a white powder. Shouldn't be a problem though.
Lo-Fi Version | Time is now: 10th June 2024 - 08:16 AM |
