B2524 |
It's a sickness. ![]() ![]() Group: Members Posts: 72 Joined: 12-November 11 From: Outside Paso Robles CA Member No.: 13,776 Region Association: Northern California ![]() |
This engine has 80k on it. I bought it to use in an autocross car and went a different direction. The fuel injection stuff is gone. I had the sheet metal powder coated. The fan shroud was bead blasted and foo-canned grey. I have a set of Webers for it with intakes and linkage. The stock exhaust is still on the engine, no muffler. I have a new gasket set for it so you can install the new seals.
I was told the motor ran strong but I have no leak down numbers. The sheet metal and Webers are off the engine. I was going to de-grease it before I put new seals in it and re-assembled it. Asking $1200. SF bay area pick up only, not interested in shipping it. For another $250 I have a race header I will include. Last weekend I gave away a bunch of parts, this is almost as good of a deal. I'll give this a couple days and if no one steps up I will clean the engine and put it back together, then leave it on the shelf as a back up. As I recall this is an EA block engine, but I will double check. |
Lo-Fi Version | Time is now: 11th July 2025 - 12:05 PM |
