| Bills914-4 |
Nov 24 2013, 08:46 AM
Member ![]() ![]() Group: Members Posts: 313 Joined: 1-March 08 From: suburbs of Miami FL. Member No.: 8,762 Region Association: South East States |
Here's a few pic's of my planned conversion to twin plug with a Pauter cam (IMG:style_emoticons/default/smile.gif) , &
either MSII or MegaJolt with edis4 x 2 for ignition, Bill D. |
| EdwardBlume |
Nov 24 2013, 08:54 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
You rock. (IMG:style_emoticons/default/aktion035.gif)
| Kirmizi |
Senior Member ![]() ![]() ![]() Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
| kid914 |
Nov 24 2013, 08:56 AM
ALWAYS lead...NEVER follow!!!! ![]() ![]() ![]() ![]() Group: Members Posts: 2,539 Joined: 9-March 11 From: Canada Member No.: 12,811 Region Association: Canada |
| Maltese Falcon |
Nov 24 2013, 12:03 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,213 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Nice machining , twin plugs rock !
More pictures as availble please. Marty |
| 0396 |
Nov 24 2013, 02:51 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Wow, congrats!
| r_towle |
Nov 24 2013, 03:02 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Any flow bench work done on the heads?
How did the numbers look? |
| Woody |
Nov 24 2013, 04:30 PM
Sandbox Rabblerouser and head toilet scrubber ![]() ![]() ![]() ![]() Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
This is what I'm talking about. (IMG:style_emoticons/default/aktion035.gif) what compression are you shooting for? (IMG:style_emoticons/default/popcorn[1].gif)
| barefoot |
Nov 24 2013, 04:56 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,488 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
Here's a few pic's of my planned conversion to twin plug with a Pauter cam If I read your calipers correctly you have a very large step increase in port size from outlet of intake manifolds to head port inlets, not a good aero flow path. Whats the thinking here ??? |
| Bills914-4 |
Nov 24 2013, 05:46 PM
Thank you for the compliments & kudos ,
Rich , I don't have any flow numbers , I ported these heads myself (budget build) I had Jorge at EMW do the twin plugs for me , I did the chamber work & cut the .060 step in the cylinder seating area ( trying to get a better seal , 103mm bore ) I had Len ( HAM ) cut the valve seats on his Serdi machine , Woody , the compression will about 11 to 1 with a .032 deck machined into the head chamber area , Barefoot , that's a picture of the intake manifold before porting & after porting , 33mm before & 40mm after , & 50mm where the 48mm throttle bodies bolt on , Thanks again guys Bill D. few more pic's ![]() |
| Jake Raby |
Nov 24 2013, 05:59 PM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Twin plug engines LOVE cylinder pressure! I always back up a few degrees on duration and start at 11:1 CR with the tightest deck possible. So far thats been good for 274HP from 2.8 liters on 91 octane. That engine had .025" deck.
You'll find that timing the engine is very, very far removed from your previous attempts and that it will optimize much leaner than it used to. |
| Bills914-4 |
Nov 24 2013, 06:41 PM
Twin plug engines LOVE cylinder pressure! I always back up a few degrees on duration and start at 11:1 CR with the tightest deck possible. So far thats been good for 274HP from 2.8 liters on 91 octane. That engine had .025" deck. You'll find that timing the engine is very, very far removed from your previous attempts and that it will optimize much leaner than it used to. Thanks Jake for chiming in , these are those vintage heads I picked up last year on your e-bay site (IMG:style_emoticons/default/smile.gif) , wow .025 deck is a little to close for me (IMG:style_emoticons/default/biggrin.gif) , the timing I've read & been told will be less ,they say as much as 6-8 degrees less , this twin plug stuff is all new to me but its time for a change on this motor ( 3yrs + running on this version) , I'd be happy with 200hp at wheels , 15 more than I have now (IMG:style_emoticons/default/biggrin.gif) , thanks Bill D. |
| Bills914-4 |
Nov 24 2013, 06:48 PM
I'm hoping this cam will be ok , it was ground way before I decided to try twin plugs Bill D.
| gothspeed |
Nov 24 2013, 07:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
AWESOME!!!! (IMG:style_emoticons/default/smilie_pokal.gif)
What EDIS modules are those? Part numbers? |
| Jake Raby |
Nov 24 2013, 07:17 PM
The cam is a little long for what I'd choose, but there's more than one way to skin a cat.
Start timing around 22*BTDC full advance to be safe, at 11:1 it shouldn't optimize at more than 24*, if it does, well, then you'll have conclusive evidence that the cam was too long :-) Glad to see the old heads getting some new life, those are several generations of vintage :-) What you'll find with twin plugs isn't so much more WOT power on the dyno and bigger numbers, but mostly insane throttle response and unreal torque gains below 4K RPM, especially with the larger bore size that needs all the help with flame propagation that it can get. |
| Bills914-4 |
Nov 24 2013, 07:32 PM
The cam is a little long for what I'd choose, but there's more than one way to skin a cat. Start timing around 22*BTDC full advance to be safe, at 11:1 it shouldn't optimize at more than 24*, if it does, well, then you'll have conclusive evidence that the cam was too long :-) Glad to see the old heads getting some new life, those are several generations of vintage :-) What you'll find with twin plugs isn't so much more WOT power on the dyno and bigger numbers, but mostly insane throttle response and unreal torque gains below 4K RPM, especially with the larger bore size that needs all the help with flame propagation that it can get. Cool , thank you very much , Bill D. |
| gothspeed |
Nov 24 2013, 09:08 PM
What valve spring arrangement will be used on these? ...... (IMG:style_emoticons/default/smile.gif)
Are any of these valves Ti? |
| Bills914-4 |
Nov 25 2013, 05:10 AM
What valve spring arrangement will be used on these? ...... (IMG:style_emoticons/default/smile.gif) Are any of these valves Ti? The modules I picked up from the bone yard out of a couple of ford escorts , I'm leaning towards megajolt ignition with edis4 x 2 with Mario's crankfire gear & bracket for vr sensor (IMG:style_emoticons/default/smile.gif) , I'm already running EFI , CB performance quicktune (older version w/o ignition ) I'll be running CB performance's vw650 dual springs , I have a set in the heads I'm running right now with titanium retainers with .560 lift , stainless valves with Ti retainers (IMG:style_emoticons/default/smile.gif) , thanks Bill D. |
| jimkelly |
Nov 25 2013, 08:41 AM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
http://thedubshop.net/
would dual plug be worth any extra HP on an otherwise stock engine? does emw have a website? carry on : ) |
| rick 918-S |
Nov 25 2013, 08:53 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,239 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
http://thedubshop.net/ would dual plug be worth any extra HP on an otherwise stock engine? does emw have a website? carry on : ) Jake posted in another twin plug thread that the twin plug worked best on large displacement engines. I would assume that would have to with the added volume of charge and the increased chamber area for the charge to expand. But I'm no expert. |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:16 PM |
