OT, Oxygen sensor |
OT, Oxygen sensor |
partwerks |
Nov 28 2013, 04:05 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Is there any way to test to see if the oxygen sensor is working correctly?
I just put in the upstream and downstream sensors, and reset the code, but a couple days later, the code came back on. I double checked to make sure the electrical connection had not worked itself loose, but seemed ok. The auto parts store checked the code, and was the upstream. |
Mike Bellis |
Nov 28 2013, 04:09 PM
O2 sensors put out a 0-1V signal, wide band O2 is 0-5V.
What is the code description? High, Low or invalid signal? Other engine conditions can make a high or low signal appear. |
partwerks |
Nov 28 2013, 04:25 PM
The guy at the auto parts store just told me it was bank 1, which I guess is the upstream/front sensor.
Mike Bellis |
Nov 28 2013, 04:29 PM
TheCabinetmaker |
Nov 28 2013, 04:36 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
You need the code# to determine the fault.
brant |
Nov 28 2013, 04:38 PM
914 Wizard Group: Members Posts: 11,635 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Yes.
With an ohm meter it kinda works. Technically an oscilloscope The fluctuation can be measured. You probably need a cat. What year, how many miles, any contamination (oil burn or leaded fuel or sea foam use?) |
partwerks |
Nov 28 2013, 04:56 PM
96 VW Jetta. Used Sea Foam. I replaced the Cat about 5 years ago.
So, it may not even be the new sensors at this point? |
brant |
Nov 28 2013, 05:07 PM
After market cats are often very short lifer. What brand did you use. Some of te cheaper brands have bee reported to have 12 month lifespans
partwerks |
Nov 28 2013, 05:59 PM
I don't recall.
How does one know it is the cat, then, and not the sensors? |
brant |
Nov 28 2013, 06:14 PM
By testing the sensors for laziness With an oscilloscope
partwerks |
Nov 28 2013, 06:19 PM
Thanks.
I'll have my electrician take a look at it for me..? |
brant |
Nov 28 2013, 06:28 PM
Pro auto shops will have a scope or be familiar enough to use an ohm
partwerks |
Nov 29 2013, 07:37 PM
I had O'Reilleys reset the code, and it was PO131, Circuit-low voltage.
So far the light has not come back one since noon. I did take the connectors off, and hose them down with some MAF sensor cleaner, and pushed them back on hard, as maybe that could have been part of the problem, or not making good contact, I wonder?? |
Lo-Fi Version | Time is now: 6th June 2024 - 08:19 AM |
