Motor oil, What weight? |
911914 |
Dec 27 2004, 11:33 PM
Member Group: Members Posts: 51 Joined: 24-December 04 From: Vancouver, Washington Member No.: 3,334 |
I am sure this has been hashed out here many times before and I don't want to start another oil thread but I be a newbie. Car I just purchased was rebuilt about 20k ago ('74 2.o) and the records show 15-40 weight has been used since rebuild and at all services. Now is this not a heavy diesel weight oil? I use this weight in my BMW 535i as recommended from factory, but a small air cooled VW mill using this heavy weight? Doesn't sound right to me. Clue me in please. Oh, engine is dual Weber's and a Web cam.
Thanks. |
markb |
Dec 28 2004, 12:23 AM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
I use 20/50 in the 914s & the Bus (2.4/6).
911914 |
Dec 28 2004, 12:40 AM
Thanks Mark, I too use the 20-50 (Castrol) in my Alfa, 911 SC and Norton bike and was planning on using it in the 914.
ChrisReale |
Dec 28 2004, 04:20 AM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
15-40 is prolly Shell Rotella, which is a good oil designed for deisel engines, but fully compatable with a VW engine. Personally, I broke my engine in on Kendall 20-50 and switched to Mobil 1 15-50. Basically, anything 10-40 or heavier is going to be ok, although 20-50 is an ideal weight
type11969 |
Dec 28 2004, 07:12 AM
Senior Member Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States |
I use 5w-30 and have plenty of pressure all around, actually when cold I almost peg my VDO pressure gauge, but I am running a new rebuild with a 30mm T1 pump.
911914 |
Dec 28 2004, 01:18 PM
New twist to my oil question. Called the PO engine builder/shop and asked why 15-40 weight oil used. He said they no longer use it, they now use 10-40. And not to use 20-50 Castrol as will cause VW motor to burn oil! Also do not use Pennzoil, Quaker State as well as Castrol! Go figure on this info from a Porsche/VW/Audi shop. Many answeres from many sources, all have their opionion. Leaves you wondering a bit doesn't it?
Root_Werks |
Dec 28 2004, 01:30 PM
Village Idiot Group: Members Posts: 8,331 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Woah you guys, you are all giving great advise, but look were the new guy lives. Around here, even in the winter, stick with 15-40. Either Delo400 or the Rotella. It is what I have used for years in my shop and many other local shops use it as well. Oil is driver habbit/climate related to a large degree. Don't put in 20/50, you will regret it. Just stick with what was being used. 15-40 is a good oil for air cooled engines.
DON'T switch to syn either. Stick with what you started with. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
SirAndy |
Dec 28 2004, 01:32 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
10-30 for us CA guys ... |
Rhodes71/914 |
Dec 28 2004, 01:54 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
I've always used 10-40 in all my VW aircooled engines.
7391420 |
Dec 28 2004, 02:04 PM
Member Group: Members Posts: 353 Joined: 6-August 03 From: boston, ma Member No.: 988 |
kendal straight 30 in winter, straight 50 in summer
Cap'n Krusty |
Dec 28 2004, 03:05 PM
Unless you live in an area where it's ALWAYS below freezing, 5w30 is WAY too thin. 20w50 is what the book says, and what we used at the dealer back when these cars were new. 5w30 is what you use in mid 90s cars, 0w30 in the newest ones. The Cap'n |
Cap'n Krusty |
Dec 28 2004, 03:06 PM
Wrong ...................... The Cap'n |
type11969 |
Dec 28 2004, 03:23 PM
how can you say it is too thin if I have plenty of oil pressure, even when the engine is hot on a 90 degree day? what are you basing this on? oil technology has come a long way since these cars were new and "the books" were written. Plus I have a gauge to monitor things. If I ran 20w-50, my cooler might just pop. 20w-50 worked great on my t1 with a worn 26mm pump on a hot day, but I can't imagine using it in this t4.
30mm pump pushes out much more flow than the stock pump, but the restrictions are the same, thus more pressure. Based on just that alone, I can get away with a thinner oil than recommended many years ago. |
SirAndy |
Dec 28 2004, 04:22 PM
has worked for me for 20+ years. never blew a T1 or T4 ... (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Andy |
Aaron Cox |
Dec 28 2004, 04:40 PM
i use 20/50 year round (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
ChrisReale |
Dec 28 2004, 11:46 PM
Forget the weight, just make sure you use oil, period. That said, the reasons why newer cars use thinner oil is because the clearances are tighter. I use 10-30 in my Subaru, 15-50 in my 914. Works for me.
dlo914 |
Dec 29 2004, 12:42 AM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
20w50 / W = Winter NOT Weight (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif)
dlo914 |
Dec 29 2004, 12:46 AM
use higher winter if your region is prone to very cold weather...but if it's a fairly new rebuilt engine any 40 weight oil is fine. I've gotten this question so often from damn customers at the FLAPS so much it's become (IMG:http://www.914world.com/bbs2/html/emoticons/finger.gif) annoying (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) . Hmm.... W could stand for hmm...wax, water, or maybe just maybe weight, b/c oil can't possibly freeze cuz it's not water...(o umm sarcasm mode initiated (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) )
Tom73 |
Dec 29 2004, 09:56 AM
Member Group: Members Posts: 180 Joined: 20-September 04 From: Central Texas Member No.: 2,792 |
My understanding has always been that a
10w30 will flow like a 10 weight when the oil is cold and then once the oil is up to temp it will flow like a 30 weight. (same for 15w40 or 20w50 etc etc) So would seem to me you would want a 10 or a 5 to get the oil flowing at start up. That is when the wear is worse and you need to get the oil moving as quickly as possible. Then when the engine warms up the oil will act like as 30 or 40 or what ever is needed in your engine. To me it would sound like you would need a 10w30 or maybe a 10w40. You would not want anything over a 10 for the cold side, then you would want a 30 or 40 for the hot side depending upon your clearances and the wear in your engine. Just my two cents..... tom... |
type11969 |
Dec 29 2004, 10:19 AM
yeah, my understanding is the same as yours Tom. I figure that as long as you don't have a pressure problem, use a thinner oil to get it where it needs to be sooner at startup, instead of just relying on whatever residual film is on the parts from the last time the engine was run. And with the oil tech of today, the oil can have a stable broader range than when these cars were made, so you can have you cake and eat it too with a thin oil at start up, and a thicker once warm.
Take a look at the passages in the case that the oil has to go through and pour out some 20w50 on a cold day. If that doesn't convince you that a thinner oil might be better . . . Well you certainly won't have a pressure problem during cold starting, but ask yourself if you really think that oil is going to make it anywhere quickly. Just my .02. |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:03 AM |
