differance between IDA and IDF manifolds?, which ones to mount throttle body (pic) |
Mueller |
Dec 31 2004, 12:11 PM
need a set of intake manifolds, not sure what the differance is between the IDA and IDF style???
need to mount something like these: Attached image(s) |
DJsRepS |
Dec 31 2004, 01:14 PM
Member Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
are those FI manifolds?
URY914 |
Dec 31 2004, 01:29 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,941 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I think IDA are wider center to center. I don't think I've seen a IDA for a T-4 before.
I'm sure I'll be corrected if I wrong (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Paul |
Mueller |
Dec 31 2004, 02:01 PM
nope, those are fuel injection throttle bodies....I need to know which style manifold these bolt onto.... |
Dominic |
Dec 31 2004, 03:20 PM
Dominic Group: Members Posts: 992 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
Mike,
Those should just bolt up to any of the normal DRLA/IDF Manifolds that are available for type 4 engines. I have an extra set of short manifolds if you are interested. Are those TB's from CB performance ? How do you mount the fuel rail ? |
Mueller |
Dec 31 2004, 05:44 PM
Let me know the damage....if within reason I'll take 'em off your hands (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
not sure if i'll use those or not...on their web site they just say $250, but I don't know if that is for one or a pair???? |
machina |
Dec 31 2004, 06:13 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
Jake had these IDA's on a motor but I think they made less power than 44IDF's but the customer demanded IDA's anyway. He's not a big fan of IDA's but maybe his new heads will work better with them. I talked to a guy that had them on his 914 and he had to cut away the rear bulkhead to make room for them. Look how the intake manifold flares out to accomodate them. Attached image(s) |
URY914 |
Dec 31 2004, 06:17 PM
I told you someone knew and would correct me. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
P |
machina |
Dec 31 2004, 06:25 PM
see, you were right after all... |
Jake Raby |
Dec 31 2004, 07:23 PM
IDAs suck on a TIV! I have many, many times made more power with a 44IDF on a TIV with stock heads- No matter how wildly modified.
With my new heads that won't hold true, because we can actually use the Volume. Use the IDF manifold. It is much more friendly and universal. The CB Throttle bodies suck because they only come in 48mm, thats is too much for a TIV unless its a 2800+ If you use them, machine some bushings to drop that down to around 44mm Max |
crash914 |
Jan 1 2005, 09:08 AM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Mike, I am running something like these....
I think that you will find that there is some differences in the linkage side to side....Why? I don't know.... I would think that there would be a mirror image... I am still working on getting the throttle bodies syncronized....pain in the ass..... In fact, I will go do it right now.... On the other hand, these work great with MS... |
Lo-Fi Version | Time is now: 31st May 2024 - 06:59 PM |
