porbmw |
Senior Member ![]() ![]() ![]() Group: Members Posts: 814 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None ![]() ![]() |
May have to repaint gas tank...
Color? Chassis black...about 60-70% gloss? Thanks |
boxsterfan |
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California ![]() |
I don't know but when I do mine I am going to have it tie-died.
worn |
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,489 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
May have to repaint gas tank... Color? Chassis black...about 60-70% gloss? Thanks I did mine in nason satin. Seemed about right. I had flatener to add, but it was very close without. You may have seen my post about rotating it with bolts inside, but in the end phosphoric acid did the heavy lifting. Sounds like you are past that stage. Good luck |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Some say L43 Grey/Black but, I'm not so sure. I think it's "blacker" (insert Spinal Tap humor here) than that.
porbmw |
The tank is pretty clean, managed to get some of overspray from a prior crappy repaint in different color.
Paint is pretty clean, non-rust and the lower part of the tank probably is close to what it looked like, out of the factory. Will see what the bodyman/painter says, and report back, with some pics when done... Thanks |
Lo-Fi Version | Time is now: 9th July 2025 - 01:29 PM |
