| thompson-mfr |
Jan 14 2014, 01:15 PM
Thompson, Ryan ![]() ![]() Group: Members Posts: 198 Joined: 30-September 08 From: Silverton, OR Member No.: 9,598 Region Association: Pacific Northwest |
Ok, I have been fighting some electrical gremlins.
74 2.0L FI 037 brain (now with 270 ohm ballast resistor) The car runs great for 10-15 minutes then dies. I tested the power relay and fuel pump relay and fuel pump itself and have power to all. After it cools off for 3-5 minutes it will start again. I have not checked for spark, but am guessing when it dies this is what is stopping. What could this be??? ECU / Brain / Computer? I know they rarely fail When I unplug my air intake sensor it has no affect on running. I thought maybe another sign of potentially a bad ecu / brain / computer. I have read it is supposed to richen the mixture. Here is a pic of my car just because I like threads with pictures. |
| boxsterfan |
Jan 14 2014, 01:43 PM
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Points or electronic ignition?
Possibly a bad coil (although some say coils "never/rarely" go bad). I replaced my coil recently (and new spark plug wires) and now my idle/lumpiness of my 2.0L has really smoothed out. Have you looked through this site? http://members.rennlist.com/pbanders/djetparts.htm#setups Make sure you ECU and MPS match. |
| DBCooper |
Jan 14 2014, 01:45 PM
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
Fuel filter, pump, tank outlet or some other restriction in fuel flow. Check the vent in the gas cap and fuel pressure at the engine.
| Jeffs9146 |
Jan 14 2014, 04:44 PM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
CHTS (Cylinder Head Temp Sensor)
Or AAR (Aux Air Regulator) |
| injunmort |
Jan 14 2014, 05:19 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
coil, and they do go bad. runs fine cold, as engine warms up, coil expands,windings separate discharge breaks down. cheap easy check before getting into chasing sparks in the dark, swap coils and rule it out first.
| 914_teener |
Jan 14 2014, 05:29 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Go to the Anders site and use the flow chart as suggested.
...then come back...... My .02. |
| iamchappy |
Jan 14 2014, 05:32 PM
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
Temp II sensor. Try jumping the fuel pump relay and see if it stays running
| Dave_Darling |
Jan 14 2014, 05:40 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Intake air temp sensor has a small effect on mixture. Head temp sensor has a very large effect.
Check to see if it is in fact spark that you are missing. Use an extra plug, taped with the outer electrode or threads on a ground, hooked to a plug wire. Crank the starter, watch for spark. --DD |
| turk22 |
Jan 14 2014, 06:59 PM
Treetop Flyer ![]() ![]() ![]() Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest |
vapor lock?
| cary |
Jan 14 2014, 10:10 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest
How does it die ????
Spitter... Sputter. Or off like a light switch? |
| falcor75 |
Jan 14 2014, 11:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia
My bet is faulty gas cap (try runnning it with the cap off and see if it stays running) or faulty coil.
| Rockaria |
Jan 15 2014, 09:23 AM
ZippidyDoDah... ![]() ![]() ![]() Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None |
When I rebuilt my 73 2.0FI I had the same exact problem. After getting everything as perfect as I could. It still died after 10 minutes. I messed with everything, focusing on the Temp Sensor II. But everything always checked out as fine.
With nothing left to fix, I thought, I finally went and rented (It was free, but needed a deposit) a fuel injector noid light from Auto Zone. It showed that power to the injectors was random after it warmed up. Sometimes it went on then not for a while then on again. I thought it could be the harness, but that tested okay. So I took out the distributor and cleaned and checked the whole thing. The trigger points were really dirty, out of position and not working correctly when I tested them. After I got it set up perfectly, cleaned the trigger points, got them set just right, and put everything back together. The car ran perfectly and has for the past year. |
| 914_teener |
Jan 15 2014, 09:37 AM
That just goes back to the adage with D-jet that you should check everything mechanical first......everything including the valves. Glad you found the problem. That was my suggestion to the OP.
| 7TPorsh |
Jan 15 2014, 10:17 AM
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California
not to hijack the thread but...I have this same typw of issue with my car and I am running Weber 40s.
If warm and car is idling, after about 5 minutes it begins to sputter, revs drop like it's going to die. If I let it go it corrects itself after 10 or 12 seconds; then fine for another 5 minutes. Happens when I am driving to...feels like car misses a beat or two then carries on. It started out of the blue. I have fuel at the carbs at 4psi...have a gauge. So maybe same type problem even tho its carbs. Now I am thinking coil or condenser is going bad. Read somewhere here that the coil should be mounted vertical...mine is more horizontal. Its a new coil with maybe a few hundred miles on it. |
| mrholland2 |
Jan 15 2014, 01:09 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 761 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
When this happened to me, it was crud in the fuel tank (tiny particles of metal that got past the "sock" and then cut thru the filter to the fuel pump) causing the pump to get blocked and over heat and shut down.
| thompson-mfr |
Jan 15 2014, 07:20 PM
| thompson-mfr |
Jan 15 2014, 07:22 PM
| boxsterfan |
Jan 15 2014, 07:25 PM
Try borrowing a coil from another member here. Also, have a look at your fuel filter and see if it is clogged.
| thompson-mfr |
Jan 15 2014, 07:27 PM
coil, and they do go bad. runs fine cold, as engine warms up, coil expands,windings separate discharge breaks down. cheap easy check before getting into chasing sparks in the dark, swap coils and rule it out first. good suggestion! I didn't think of this. My coil only has 15,000 miles on it and is shiny new looking, so didn't even consider it. Then again, that is over 7 years. That would be a cheap easy fix. |
| Jeffs9146 |
Jan 15 2014, 07:28 PM
CHTS..........Just saying!! (IMG:style_emoticons/default/chair.gif)
Lo-Fi Version | Time is now: 2nd May 2026 - 01:20 PM |
