> LAST DAY- The coveted triangle window seals! Closes Feb 14th, GB $92 a set..+shipping. Yes left and right! ? $120 after
Mikey914
post Jan 16 2014, 12:54 AM
The rubber man
Yes, I've been working on these for awhile. The fist ones were copies of the best I could find, and not as good as OEM, I made then as cast molds using catalyzed rubber. Sometimes it didn't flow all the way as the pressure required to make these meant that I wound up throwing out about 1/2 of the ones I made. I cheated the formulation to make it flow better and found that didn't work as well.
The only choice was aluminum tooling. It can take the pressure and allow for using a compound that flows and and looks correct.
Well I finally did it. I actually improved the little skinny part on the back edge of the seal so that it actually fills the little void in the indentation on the inside of the door. This is something the OEM current version does, but it's a little loose.
So below is a picture of the OEM and one of my seals. Guess which one is mine.
I'm posting in larger files so you can zoom in on the details.
This is one of the big projects I've been trying to get off my plate for about 18 months.
5 Pages V  1 2 3 > »
Replies(1 - 19)
Mikey914
post Jan 16 2014, 12:55 AM
The rubber man
more
Mikey914
The rubber man
more
Mikey914
post Jan 16 2014, 12:56 AM
The rubber man
more
Mikey914
The rubber man
of course more
Mikey914
post Jan 16 2014, 12:57 AM
The rubber man
one more
CptTripps
post Jan 16 2014, 01:19 AM
:: Punch and Pie ::
Those look perfect. I'm in!
Mikey914
post Jan 16 2014, 01:31 AM
The rubber man
Inside, inside, top and right are mine.
ConeDodger
post Jan 16 2014, 01:35 AM
Apex killer!
Do I have to??? (IMG:style_emoticons/default/biggrin.gif)
Niklas
post Jan 16 2014, 04:33 AM
Porsche 914 Sweden
3 sets for me.
walterolin
post Jan 16 2014, 07:10 AM
Early and late the same?
I'm in for one set, early.
raw1298
post Jan 16 2014, 07:17 AM
Nice.
914_teener
post Jan 16 2014, 07:26 AM
Wow......very cool....I am in for set Mark.
FourBlades
post Jan 16 2014, 08:42 AM
From Wreck to Rockin
How do you have time to make all these killer parts???
I still have a set of your last batch that I have not even installed yet...
Let me put those on my car and then I can order the replacements. (IMG:style_emoticons/default/biggrin.gif)
John
ThePaintedMan
post Jan 16 2014, 08:58 AM
(IMG:style_emoticons/default/piratenanner.gif) These are awesome Mark! I've been waiting for these to come down in price a little before ordering a set. They'll be on my next round of goodies to order from you for sure. Thanks for all of your hard work.
billh1963
post Jan 16 2014, 08:59 AM
Car Hoarder!
I'm in for one set
no1uno
post Jan 16 2014, 09:04 AM
I'll take a set.
mharmon
post Jan 16 2014, 09:33 AM
I'm in for a set
Mikey914
post Jan 16 2014, 10:48 AM
The rubber man
QUOTE(walterolin @ Jan 16 2014, 05:10 AM) *
Early and late are the same.
Mikey914
post Jan 16 2014, 10:51 AM
The rubber man
QUOTE(FourBlades @ Jan 16 2014, 06:42 AM) *
John
These are the tip of the iceburg. I'm doing a ton of stuff for Stoddard too!
It's how I have been able to afford to make the tooling for this and more new stuff.
5 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 9th June 2026 - 06:50 PM
