What I did on semester break, Out of the classroom and into the garage |
Dave-O |
Jan 2 2005, 11:20 PM
Is winter done yet? Group: Members Posts: 511 Joined: 26-August 03 From: Minneapols, MN Member No.: 1,082 |
Finally a chance to get in the garage and get my 914 ready for the next autocross season. This car is being built on a very tight budget. Many of the parts are being fabricated by myself. When i finish my homemade front anti-sway bar i will post a complete set of pictures of the build. In the meantime i made a lot of progress on other things. The first order of business was to groove and regrease all my badly creaking suspension bushings.
Attached image(s) |
Dave-O |
Jan 2 2005, 11:21 PM
Next up, I installed the rear bar (kindly donated by a club member). I made up these brackets to instal It.
Attached image(s) |
Dave-O |
Jan 2 2005, 11:23 PM
And in goes the bar. In this picture you can also see the repainted used koni reds i installed and the trailing arm i used to replace my old bent one.
Attached image(s) |
Dave-O |
Jan 2 2005, 11:26 PM
Finally i got started on some interior projects. I first made a set of door panels out of 3/16" plywood. These pieces are actually lighter than the original paper-board and a much much more durable. I re-used the metal piece on the top of the old panel.
Attached image(s) |
Dave-O |
Jan 2 2005, 11:29 PM
After upholstering, I hope the "waves" in the top folded part even out with time. My mistake was gluing the vinyl of this portion to the padding underneath. For future reference leave the padding "sit" inside the vinyl flap so it is not distorted by the pinched vinyl underneath. The handle is simply an overhead handle on a saturn parts car I have around. I covered the handle portion with vinyl and painted the end caps. These panels turned out much better than I expected, this was the first time I’ve done door panels.
Attached image(s) |
Dave-O |
Jan 2 2005, 11:31 PM
crap, wrong picture. Here is the picture of the finished door panel.
Attached image(s) |
airsix |
Jan 2 2005, 11:32 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
Dave,
I'm interested to see your front sway-bar project. I love DIY stuff. Are you modifying a bar off of something else, or making up a new bar from scratch? If from scratch do you have plans for getting it heat treated and tempered to spring-temper? -Ben M. |
Dave-O |
Jan 2 2005, 11:33 PM
I also re-covered the dash face with a felt material. Since i eliminated the radio and glove box i had to make new backing panels out of aluminum sheet.
Attached image(s) |
Dave-O |
Jan 2 2005, 11:35 PM
Here is the dash face installed. I still need to find a good knee pad. In this picture you can also see the 917-style shift knob...a christmas present from my dad (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Attached image(s) |
Dave-O |
Jan 2 2005, 11:36 PM
I also picked up a set of these (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Attached image(s) |
Dave-O |
Jan 2 2005, 11:42 PM
well i guess i can let the cat out of the bag (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) . I will be using a welt 22mm bar. I am making the rest of the hardware myself. This first picture is of the homemade bushing holder. I also made the backing plate and welded it into the car. Attached image(s) |
Dave-O |
Jan 2 2005, 11:43 PM
in the car
Attached image(s) |
Dave-O |
Jan 2 2005, 11:46 PM
Here is the start of the adjustable "rod ends"
Attached image(s) |
Dave-O |
Jan 2 2005, 11:47 PM
welded
Attached image(s) |
Dave-O |
Jan 2 2005, 11:48 PM
I also finished making the adjustable rod connectors. This seemed like the easiest design to fabricate
Attached image(s) |
Dave-O |
Jan 2 2005, 11:50 PM
i just got started making the attachment point when i had to go back to work. I'll do the rest over spring break,
Attached image(s) |
736conver |
Jan 3 2005, 12:35 AM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
Looks good Dave.
Hey are those my Konis in action there. I hope they were good. As for your door panels you should glue the back side of the top. Just like the factory did. Or you can also staple them. I've done both and the both work well. Did you put in a little foam cushion too? If you do them over I have a staple gun and the small 4mm staples I could loan you. Here's an example I did for a customer. Attached image(s) |
736conver |
Jan 3 2005, 12:36 AM
Attached image(s) |
Dave-O |
Jan 3 2005, 08:38 AM
Brian, I glued the backside like the factory did. My problem was that i glued the pad that sits inside the top part down to the vinyl below (which is really uneven because it is pinched by those tabs). Then i glued the top piece of vinyl to the distorted pad. I'm going to try and work the vinyl loose from the pad below and as a last resort take the top apart again.
Yes, those are your old koni's. They seem to be working fine. I put a pair of your fronts in too. Thanks! David |
736conver |
Jan 3 2005, 08:53 AM
Glad the Koni's worked out. Give a call or email if you need anything else. I need to empty that trailer out.
Brian |
Lo-Fi Version | Time is now: 9th June 2024 - 06:55 PM |
