How to cut steel pushrods, Valve Train Set-Up |
Highland |
Jan 23 2014, 09:25 AM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
How to most people get their pushrods cut? Should I take the pushrods to the same machinest that worked on my engine parts (crank, cylinders, rods,...) or to a regular machine shop?
Also, what tolerance should I give them? +/-0.001"? Below are my numbers for a Raby 9590 cam with 0.426" lift for exhaust and intake. Are these numbers typical? Cylinder.....Intake Lift....Intake Rod Length 1...............0.432................10.567" 2...............0.433................10.607 3...............0.431................10.640 (required 0.03 shim) 4...............0.424................10.578 Cylinder.....Exhaust Lift....Exhaust Rod Length 1...............0.410...............10.623" 2...............0.409...............10.618 3...............0.412...............10.663 (required 0.03 shim) 4...............0.410...............10.612 |
stugray |
Jan 23 2014, 10:09 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I believe I cut mine with a hacksaw ~1/16" long and then ground them down with a bench belt sander.
I was able to get them very accurate. I was also able to find a length that worked fine for all valves. I did not have to make custom lengths for each valve. The number I used is written down at home but was very close to what Jake reccommends starting with. I also shimmed my rockers up by a small amount (.049 if I recall correctly I have to look). But I have pretty big valve lift (.505 & .475 ish) We sanded the shims to match exactly between the 8 locations. |
'73-914kid |
Jan 23 2014, 10:34 AM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
I think there was someone who took them to a machine shop to have them cut on a lathe, and there was some misunderstanding as to what length they were supposed to be cut at, and ALL ended up too short. ie. ruined
Any machine shop can do it, but a hacksaw and a file to get the surface nice and flat would probably do just fine. If you take it to a machine shop though, make sure you talk to the guy who will be doing the cutting and explain explicitly how they are to be cut.... Oh, a chop saw with a locking jaw to stabilize the pushrods and make a perpendicular cut also works well. |
nathansnathan |
Jan 23 2014, 10:37 AM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
I had a place in long beach cut pushrods once. They said they'd use a lathe, but when I picked them up they said they used a hacksaw and you could tell by the gaps. (IMG:style_emoticons/default/mad.gif) The ends only seat on the longest part if they're not faced. Personally I would go to +/- 5 tenths - keep them within a thousandths of an inch and do them per valve - not gonna happen with a hacksaw. (IMG:style_emoticons/default/biggrin.gif)
I recall reading a post by Jake on thesamba about the 9590 cam, you would see about .426 intake and .415 exhaust on account of the different ratios of the rocker arms. |
worn |
Jan 23 2014, 10:46 AM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
How to most people get their pushrods cut? Should I take the pushrods to the same machinest that worked on my engine parts (crank, cylinders, rods,...) or to a regular machine shop? Also, what tolerance should I give them? +/-0.001"? Below are my numbers for a Raby 9590 cam with 0.426" lift for exhaust and intake. Are these numbers typical? Cylinder.....Intake Lift....Intake Rod Length 1...............0.432................10.567" 2...............0.433................10.607 3...............0.431................10.640 (required 0.03 shim) 4...............0.424................10.578 Cylinder.....Exhaust Lift....Exhaust Rod Length 1...............0.410...............10.623" 2...............0.409...............10.618 3...............0.412...............10.663 (required 0.03 shim) 4...............0.410...............10.612 I used a lathe. I also used a home made adjustable rod to get the length correct and the angles right. Centering on mid lift is a good approximation to optimum valve train, but the angles are what you are really going for. If you use a saw, you can true the ends by putting them in a drill press and running them down on an abrasive to grind away the high spots. If you are careful you can even chuck into an electric drill and go against a grinding wheel. I took a machining class in college. The first assignment was to make a 1 inch steel cube with a file, flat within 0.001, square all around. A LOT harder than it sounds, and worth the effort put in. |
stugray |
Jan 23 2014, 11:08 AM
QUOTE on account of the different ratios of the rocker arms. Oh, but I thought the rocker ratios were supposed to be exactly the same..... |
nathansnathan |
Jan 23 2014, 12:22 PM
QUOTE on account of the different ratios of the rocker arms. Oh, but I thought the rocker ratios were supposed to be exactly the same..... Since it's not a split lift cam, there's nothing else but the rocker ratio that could account for the difference everyone is seeing, right? That's definitely what he said, anyway, 1.25 vs 1.3 to 1. I found the link. http://www.thesamba.com/vw/forum/viewtopic.php?t=236531 |
74914LE |
Jan 23 2014, 12:40 PM
Member Group: Members Posts: 136 Joined: 6-April 04 From: Fort Worth, TX Member No.: 1,895 |
Take them to a quality machine shop, and discuss in detail what you want. Call out the exact length for each, when finished, with ends attached. Make sure that they measure, and mark each pushrod with the exact meansurements you want. A quality machinist will get it right.
Lots of great info on this topic from Jake Raby. |
HAM Inc |
Jan 23 2014, 12:59 PM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
aircooledtechguy |
Jan 23 2014, 01:15 PM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
This is how I do mine and they come out spot-on every time.
http://aircooledtech.com/custom_push_rods/ |
Jake Raby |
Jan 23 2014, 06:15 PM
An arrow cutter (archery) is the absolute best way. I can cut 8 pushrods to an accuracy of .003" in less than 90 seconds.
Lo-Fi Version | Time is now: 9th June 2024 - 03:47 PM |
