> Brake light issue
sled9146
post Jan 27 2014, 09:35 AM
I burn out both my brake light elements when I apply the brakes. Replaced the switch at the pedal cluster and cleaned the taillight housing contacts.
Bad ground?
Thanks
Sled
Replies(1 - 11)
Spoke
post Jan 27 2014, 10:56 AM
Jerry
That is really bizarre. These are 1157 bulbs correct? They are rated for 12V and shouldn't die when energized.
The only thing I could think would be a bad ground or VBAT that constantly opened and closed the circuit.
Did this just start happening?
toolguy
post Jan 27 2014, 11:21 AM
That doesn't make 'electrical sense' to burn out only the brake bulbs/ / / . . you'd need in excess of 12 volts to instantly burn out the correct bulb. . . or you're using a 6 volt bulb by mistake.
So are your burning the bulb out or blowing the fuse which make more sense. . .
balljoint
post Jan 27 2014, 07:33 PM
Wrong fuse?
Mike Bellis
post Jan 27 2014, 08:20 PM
Resident Electrician
Make sure your lamp base looks like this... Note the oval electrode. European style.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.pelicanparts.com-10496-1390875608.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.rallylights.com-10496-1390875609.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/d114hh0cykhyb0.cloudfront.net-10496-1390875610.3.jpg)
Not like this... These will cause a bad connection and sometimes short.
(IMG:http://www.914world.com/bbs2/uploads_offsite/a248.e.akamai.net-10496-1390875610.4.jpg)
r_towle
post Jan 27 2014, 08:24 PM
Custom Member
Voltage regulator????
How much voltage is going through the circuit when the brakes are applied?
sled9146
post Jan 28 2014, 12:16 AM
QUOTE(Spoke @ Jan 27 2014, 08:56 AM) *
Yes, just started happening.
Old bulbs were probably in for the last 20 years!
VBAT?
Thanks
r_towle
post Jan 28 2014, 07:32 AM
Custom Member
QUOTE(sled9146 @ Jan 28 2014, 01:16 AM) *
VBAT?
Thanks
Vbat is the voltage of the battery for the CMOS settings on a PC computer....which we do not have.
He may be talking about your battery itself....which may be on its way out with a short in a cell or two....worth a check with a meter to see.
sled9146
post Jan 28 2014, 06:36 PM
QUOTE(r_towle @ Jan 28 2014, 05:32 AM) *
VBAT?
Thanks
Good afternoon all
THANK YOU MIKE!!!!!!
It appears that the problem has been solved, but I am not really sure why.
I went out looking for the 1157's like Mike had in his reply, the ones with the elongated contact patch. FYI, I had been purchasing Sylvania (made by OSRAN) bulbs, BUT, they only had the dot and not the elongated patch for the contact surface. Finally, after hitting Autozone, Kragen, and one independent, I found some at NAPA. The correct style is available as a Wagner product 17881. They were NOT available on the rack in the store, but rather on the shelf in back(Sylvania is on the shelf) for the parts counter to draw from.
Got home, made the install and they have worked for the whole day, so we may have found the solution to the mystery problem.
Thanks MIKE
Sled
Mike Bellis
post Jan 28 2014, 07:20 PM
The dot type base can push the socket pin into the housing. It can also short the two if it bends the pins just right. (IMG:style_emoticons/default/smile.gif)
Rotary'14
post Jan 28 2014, 07:55 PM
It's peculiar to the european style socket!? wow,,, learn something new everyday.
Thanks Mike!
Cap'n Krusty
post Jan 30 2014, 09:30 AM
Cap'n Krusty
I use whatever name brand is available, and I have done so professionally, without problems, for over 40 years. I think the contact patch issue is BS.
The Cap'n
- Lo-Fi Version Time is now: 13th November 2025 - 10:41 PM
