Reverse of the motor drop, ...and on the way back |
boxsterfan |
Feb 10 2014, 05:29 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
So, I am slowly planning on getting my motor dropped sometime soon. I have picked up a wooden floor dolly from Harbor Freight and have access to 2 floor jacks plus some jackstands as needed. I have been reading over the engine drop procedure over on the bird site:
http://www.pelicanparts.com/techarticles/9...engine_drop.htm When dropping the motor, the article describes that as you unbolt the motor it will drop about 1/2" on to your awaiting wooden dolly. So when putting the motor back in, how does one account for getting the motor lifted back up that 1/2"? Just muscle it in? Tiny floor jack? Note: I am your weekend warrior, kick the wife's car out of the garage, have hardly enough tools, and first time motor dropper. (IMG:style_emoticons/default/smile.gif) |
wndsnd |
Feb 10 2014, 05:42 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
I did mine myself with a bad heart, seven stents, and an ICD!
Plan it out, and have the balance point right. You should do fine. I think most of us work alone. Dont go under anything without redundant supports. When I yell for my wife she thinks something has dropped on me but I just want a wrench! (IMG:style_emoticons/default/smile.gif) John Good Luck it's a fun project...... |
Krieger |
Feb 10 2014, 05:45 PM
Advanced Member Group: Members Posts: 4,723 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
The way I do it while the engine is in the car you place a floor jack under the engine cross bar to hold it in place. One at a time replace the two large bolts that go between the cross bar and body with a much longer threaded rod (1/2" or 5/8" stock cut down to like 10" in length With two nuts locked together on the top side and one nut below the crossbar) Once this is done get your floor jack under the tranny. I use a nice scissors jack. instead. Wind each of the nuts on the crossbar down a little one at a time, then the jack under the tranny until the entire assemble is on the dolly. A couple of 2 x 4s to steady it all on the dolly. Once the engine is on the dolly you will need to then raise the car up on jack stands high enough to roll out engine and trans.
mrbubblehead |
Feb 10 2014, 05:46 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
what i do is put the ass end of the the car up as high as it will go. then i lay my carpet dolly over the floor jack. then roll the 2 under the car toward the the rear of the engine/ front of the trans. then jack the jack up to where the puck of the jack is on the back of the engine. the center of gravity is pretty close there. once the puck of the jack touches the engine i give it a little more. just a little pressure....
then remove engine and trans mount bolts and slowly lower the jack right onto the dolly. as your bringing it down you need to move the dolly around till you hit the sweet spot. once the engine is on the dolly,pull the jack out and then pull the dolly with the engine and trans combo. pretty easy actually. reverse the order when you installl. slide the combo under the car, then slide the jack under the engine, jack the engine into place. |
sfrenck |
Feb 10 2014, 06:46 PM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
Best way I did it was to put a 2x4 between the dolly and the front engine bar, roll the engine under the car, lower the back end of the car (without rear wheels) and bolt it up.
Doesn't work as well if you don't raise the front of the engine up with the wood block as the front mounts don't touch before the rear brake shields hit the ground (and you can't lower the car any longer). |
bigkensteele |
Feb 10 2014, 07:41 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
The way I do it while the engine is in the car you place a floor jack under the engine cross bar to hold it in place. One at a time replace the two large bolts that go between the cross bar and body with a much longer threaded rod (1/2" or 5/8" stock cut down to like 10" in length With two nuts locked together on the top side and one nut below the crossbar) Once this is done get your floor jack under the tranny. I use a nice scissors jack. instead. Wind each of the nuts on the crossbar down a little one at a time, then the jack under the tranny until the entire assemble is on the dolly. A couple of 2 x 4s to steady it all on the dolly. Once the engine is on the dolly you will need to then raise the car up on jack stands high enough to roll out engine and trans. This is my method of choice. It only takes one jack, is very safe, and you don't have to "balance" anything. Because you are slowly lowering it in a very controlled fashion, you can easily manage the injectors hitting and you will notice if anything is still connected. I don't understand why Andy and I are apparently the only two who do it this way. |
bdstone914 |
Feb 10 2014, 07:49 PM
bdstone914 Group: Members Posts: 4,531 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The way I do it while the engine is in the car you place a floor jack under the engine cross bar to hold it in place. One at a time replace the two large bolts that go between the cross bar and body with a much longer threaded rod (1/2" or 5/8" stock cut down to like 10" in length With two nuts locked together on the top side and one nut below the crossbar) Once this is done get your floor jack under the tranny. I use a nice scissors jack. instead. Wind each of the nuts on the crossbar down a little one at a time, then the jack under the tranny until the entire assemble is on the dolly. A couple of 2 x 4s to steady it all on the dolly. Once the engine is on the dolly you will need to then raise the car up on jack stands high enough to roll out engine and trans. This is my method of choice. It only takes one jack, is very safe, and you don't have to "balance" anything. Because you are slowly lowering it in a very controlled fashion, you can easily manage the injectors hitting and you will notice if anything is still connected. I don't understand why Andy and I are apparently the only two who do it this way. Sounds like a good way but you would have to use 3/8" threaded stock not 5/8 or 1/2 as the original bolts are 10mm and the larger stock will not fit. Bruce |
Cap'n Krusty |
Feb 10 2014, 08:05 PM
The way I do it while the engine is in the car you place a floor jack under the engine cross bar to hold it in place. One at a time replace the two large bolts that go between the cross bar and body with a much longer threaded rod (1/2" or 5/8" stock cut down to like 10" in length With two nuts locked together on the top side and one nut below the crossbar) Once this is done get your floor jack under the tranny. I use a nice scissors jack. instead. Wind each of the nuts on the crossbar down a little one at a time, then the jack under the tranny until the entire assemble is on the dolly. A couple of 2 x 4s to steady it all on the dolly. Once the engine is on the dolly you will need to then raise the car up on jack stands high enough to roll out engine and trans. Must be pretty interesting putting a 1/2"-5-8" piece of threaded rod through a 10mm (about 3/8") hole ........................... The Cap'n |
Krieger |
Feb 10 2014, 08:24 PM
DOH!
bigkensteele |
Feb 10 2014, 08:48 PM
Highland |
Feb 10 2014, 09:55 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I need to drop my engine myself for the 1st time soon too.
Would a HF jack table (with the handle down) work so there won't be any balancing issues with the engine/transmission assembly? |
rosenfe |
Feb 10 2014, 11:33 PM
Senior Member Group: Members Posts: 556 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
I need to drop my engine myself for the 1st time soon too. Would a HF jack table (with the handle down) work so there won't be any balancing issues with the engine/transmission assembly? i just put engine and trans in for the first tme.i used 2 jacks to lift car up high enough to get engine underneath.engine was on harbor freight motorcycle jack,trans was supported with a piece of wood.i raised engine enougt to get bolts almost into engine bar,then lowered body down,watching that everything fit and didnt get snagged.bolted engine and trans. |
boxsterfan |
Feb 11 2014, 11:00 AM
I need to drop my engine myself for the 1st time soon too. Would a HF jack table (with the handle down) work so there won't be any balancing issues with the engine/transmission assembly? I looked at those jack tables from HF but opted for the $10 wooden dolly. The hydraulic table would work well however as the handle/bar comes off. Thanks to all for the replies. I'm hoping to perform this drop sometime in the next month. |
MartyYeoman |
Feb 11 2014, 02:23 PM
Senior Member Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Might I suggest, you label everything you disconnect with reassembly in mind.
(IMG:style_emoticons/default/idea.gif) |
boxsterfan |
Feb 11 2014, 02:56 PM
Might I suggest, you label everything you disconnect with reassembly in mind. (IMG:style_emoticons/default/idea.gif) I will take this into consideration. (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/biggrin.gif) |
barefoot |
Feb 11 2014, 05:35 PM
Senior Member Group: Members Posts: 1,279 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Along with the movers dolly, i made up a wood cradle that goes from the front mount bar back to the end of the tranny (see photos). This sits atop the dolly. then I slipped my floor jack under the dolly and positioned it under the balance point to the motor/tranny assay.
Took a few tries to get the balance point right, but once there I kept most weight on the jack while loosening the motor mounts. once clear of the mounts, lowered all the way till the cradle sat on the dolly. Rolled the unit out from under the car, then lifted the ass end and slipped the jack out from under. Now had the unit on a rolling cart. |
Kirmizi |
Feb 11 2014, 09:09 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Might I suggest, you label everything you disconnect with reassembly in mind. (IMG:style_emoticons/default/idea.gif) I will take this into consideration. (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/biggrin.gif) Label and take some pictures. This will help with reassembly and orientation. (IMG:style_emoticons/default/beerchug.gif) |
mepstein |
Feb 11 2014, 09:43 PM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Might I suggest, you label everything you disconnect with reassembly in mind. (IMG:style_emoticons/default/idea.gif) I will take this into consideration. (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/biggrin.gif) Label and take some pictures. This will help with reassembly and orientation. (IMG:style_emoticons/default/beerchug.gif) I'm a newbie at engine drops but when I put the engine and trans back into the car, all the connections were pretty obvious. Mark the shift rod connection and you should be able to connect it all up without any fine tuning. |
BuddyV |
Feb 11 2014, 09:59 PM
Robert Group: Members Posts: 555 Joined: 8-April 05 From: Santa Rosa, CA Member No.: 3,898 Region Association: Northern California |
I've done it twice, and I am dopey.
..... the final "release" when the final threads unhook is more tame than you would think. Just lower the car as far onto the dolly as you can..... it will make sense when you are doing it. I recall the "reach" under to undo the motor mounts was the trickiest the first time I did it..... when it finally dropped safely onto the dolly, I remember thinking "whoe! good thing no body parts were in the way.... didn't expect that just then!". But again, it all made more sense while I was dropping the engine than when I read the Pelican article 14 times. Cheers! |
BuddyV |
Feb 11 2014, 10:02 PM
So, I am slowly planning on getting my motor dropped sometime soon. I have picked up a wooden floor dolly from Harbor Freight and have access to 2 floor jacks plus some jackstands as needed. I have been reading over the engine drop procedure over on the bird site: http://www.pelicanparts.com/techarticles/9...engine_drop.htm When dropping the motor, the article describes that as you unbolt the motor it will drop about 1/2" on to your awaiting wooden dolly. So when putting the motor back in, how does one account for getting the motor lifted back up that 1/2"? Just muscle it in? Tiny floor jack? Note: I am your weekend warrior, kick the wife's car out of the garage, have hardly enough tools, and first time motor dropper. (IMG:style_emoticons/default/smile.gif) ...... let me know if you want some company when you are ready to do the drop. You can get everything unhooked and labeled. I can help with the actual drop...... I've done it a couple of times. Cheers! ps - I live in the north bay. Easy drive for me |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:46 AM |
