Just bought a V-8 out of San Diego |
sellhammer |
Mar 13 2014, 12:12 AM
Newbie Group: Members Posts: 12 Joined: 9-March 14 From: seattle Member No.: 17,096 Region Association: None |
I just bought a V-8 conversion out of San Diego. Was looking for some input on it. I know the Tranny is a weak point in these conversions. Has anyone had any issues with these blowing up at high revs? Also any idea of what my future looks like with this car? Maintenance, headaches, anything un expected. I am a first time poster and am looking for any info i can get. I posted the link below.
http://clients.automanager.com/005654/vehi...door+coupe.html |
messix |
Mar 13 2014, 12:22 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
messix |
Mar 13 2014, 12:28 AM
it looks like they have that 901 first gear removed or locked out, that's a good thing. the first gear just kind of hangs off the back of the stack unsupported and is the first thing to go bang on a high torque engine swap.
the tranny will cope ok as long as you don't do clutch drop launches and treat it like a muscle car. there are a couple of v8 convert guys around here in the pnw and I'm sure they will speak up here. we'll have to get the teener tuesadys started up again soon and meet up with you. |
Olympic 914 |
Mar 13 2014, 05:53 AM
Group: Members Posts: 1,673 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Probably want to pick up a cover for the shifter on the transmission.
rick 918-S |
Mar 13 2014, 06:34 AM
Hey nice rack! -Celette Group: Members Posts: 20,473 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Looks well put together. (IMG:style_emoticons/default/welcome.png)
Maltese Falcon |
Mar 13 2014, 09:46 AM
Advanced Member Group: Members Posts: 4,686 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Make some permanent bracketing on that rippled radiator hose near the outboard water pump.
When the heat of the engine bay causes the large zip tie to fail, that coolant hose will get munched on the pump pulley. Also with the coolant copper piping running under the unibody AVOID speed bumps. Also your brake prop. valve is replaced with a tee fitting, but some folks like to run with it, do a search and read up on this. Replace the dust boot over the (firewall) shifter joint for good measures. Otherwise it is a clean Renegade car ! Marty |
JRust |
Mar 13 2014, 10:15 AM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Looks to be well sorted. Yeah the 901 will handle it without the use of first. Also if you are smart & don't do Clutch drop as Troy mentioned. The 901 is stout but you are on the upper range. So hammering down on the throttle isn't a good idea. With that horsepower you won't need to anyway. So if you are a sensible driver you'll be just fine. Congrats & (IMG:style_emoticons/default/welcome.png)
mittelmotor |
Mar 13 2014, 11:39 AM
Member Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None |
Looks like a nicely sorted car!
You might want to look into getting some "H" gears for 5th, as it will reduce the cruising revs. Do you know output of engine? As others have said, 901 will live at 300 bhp/300 torque if not abused. Also, I don't know what clutch is fitted, but my kit came with a Kevlar disc that's good for 500 bhp…way overkill for my 300-bhp engine…so I replaced it with a more conventional disc from Kennedy Engineered Products, and the clutch take-up is much smoother now. Good luck! |
jim_hoyland |
Mar 13 2014, 12:46 PM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Just checked your VIN 4742916900 in the VIN database; it had been entered in it's previous life.
You can update by adding the VIN again |
crawler |
Mar 13 2014, 01:23 PM
Newbie Group: Members Posts: 20 Joined: 25-July 08 From: mesa, Arizona Member No.: 9,356 Region Association: None |
Make some permanent bracketing on that rippled radiator hose near the outboard water pump. When the heat of the engine bay causes the large zip tie to fail, that coolant hose will get munched on the pump pulley. Also with the coolant copper piping running under the unibody AVOID speed bumps. Also your brake prop. valve is replaced with a tee fitting, but some folks like to run with it, do a search and read up on this. Replace the dust boot over the (firewall) shifter joint for good measures. Otherwise it is a clean Renegade car ! Marty Did someone use copper pipe?It looks like something you would see in some-ones home. I would change that to some thing that will last.You can do better. |
Andyrew |
Mar 13 2014, 01:46 PM
Make some permanent bracketing on that rippled radiator hose near the outboard water pump. When the heat of the engine bay causes the large zip tie to fail, that coolant hose will get munched on the pump pulley. Also with the coolant copper piping running under the unibody AVOID speed bumps. Also your brake prop. valve is replaced with a tee fitting, but some folks like to run with it, do a search and read up on this. Replace the dust boot over the (firewall) shifter joint for good measures. Otherwise it is a clean Renegade car ! Marty Did someone use copper pipe?It looks like something you would see in some-ones home. I would change that to some thing that will last.You can do better. Copper pipe is fine. This is a clean conversion and it obviously works. I dont think its a renegade car, the cooling setup is much different. Great looking car! Looks well sorted and has high quality parts on it. What did you pick it up for? |
Andyrew |
Mar 13 2014, 01:50 PM
Buy a spare throttle cable and clutch cable and keep them in the trunk. With the v8 heat the clutch cable might break. The throttle cable is always something that has the potential to break because of all the bends required for the carb.
Just buy factory style Terry cables from Pelican Parts or similar, nothing custom here. |
computers4kids |
Mar 13 2014, 08:07 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
(IMG:style_emoticons/default/welcome.png) Yes, there's quite a few SBC conversions here on the board. Yours looks very well put together. Copper pipes are fine, but like said stay away from speed bumps. You might want to get rid of the air cleaner...they are notorious for catching on fire.
Nice car...they are a ton of fun to drive. Mark |
Jeff Hail |
Mar 13 2014, 10:06 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
Nice good looker. Looks like a fun car.
Better check the nut holding the nylon pulley for the clutch cable... looks like its ready to come off. |
sellhammer |
Mar 13 2014, 10:33 PM
Thanks for the feedback. The car is paid for... Flying down on the 23rd to pick it up. First car ever bought before a test drive. I did have a buddy of mine drive it and he like it alot. I will hit you guys up when i get it up here. I paid much less than the asking price. Often it is not what you know it is who...
jim_hoyland |
Mar 14 2014, 06:33 AM
Thanks for the feedback. The car is paid for... Flying down on the 23rd to pick it up. First car ever bought before a test drive. I did have a buddy of mine drive it and he like it alot. I will hit you guys up when i get it up here. I paid much less than the asking price. Often it is not what you know it is who... Shoot some pics for viewing; sounds like a great find ! (IMG:style_emoticons/default/smile.gif) Attached image(s) |
Chris H. |
Mar 14 2014, 07:21 AM
Senior Member Group: Members Posts: 4,031 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Man I really like how the bodywork was done. Looks very custom but not weird at all which is hard to pull off. The bumpers look nice and thin and so do the front flares. That radiator setup is unique too. You might want to pick up some padding for the roll cage. Even the slight banging around while you get used to the car can be painful on the noggin, knees, and elbows.
crawler |
Mar 14 2014, 09:14 AM
Copper will work,maybe! You will never see it on Aircraft or on a new car. I would use it until it fails.The car looks great but I would like it better if it was mine.
AZ914 |
Mar 14 2014, 09:18 AM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
You might want to PM member 914GT about the cooling pipes. I think he used iron or something, he can jack the car up on those things.. no worries about breaking.
barefoot |
Mar 14 2014, 10:54 AM
Senior Member Group: Members Posts: 1,279 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
I don't see any fresh air ventilation, looks like the cowl air entry is blanked off, don't know if it has any heat either, photos don't show enough detail
Lo-Fi Version | Time is now: 1st June 2024 - 09:59 PM |
