Throttle body return spring, 1.8 L-Jet setup |
MrKona |
Apr 20 2014, 10:51 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
Used to read the 914 parts diagram catalog like a novel and thought I had it all figured out. But after seeing an old picture in the Classifieds today of an L-jet throttle body with a spring, I realized I don't have this spring.
Porsche calls it the Return Spring 022 129 881 F. Can someone with a 1.8 L-Jet please post a picture of where this spring connects. I can see where it connects on the TB, but what about the other end? On the plenum, or body sheet metal somewhere? Thanks, Bryan |
Dave_Darling |
Apr 21 2014, 08:29 AM
On my old 1.8, it connected to a hole in the rear (vertical) engine tin. I don't know if that was stock or not, though.
--DD |
type47 |
Apr 21 2014, 09:29 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
smarens |
Apr 21 2014, 09:48 AM
Member Group: Members Posts: 69 Joined: 15-March 14 From: Michigan Member No.: 17,121 Region Association: None |
I have a 1975 1.8, didn't drive it today, will take picture tonight for you
Dave_Darling |
Apr 21 2014, 10:18 AM
The pic that Type47 shows is the way I remember mine being.
--DD |
tomeric914 |
Apr 21 2014, 10:24 AM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
What is the actual purpose of the long spring? It seems like it prevents the throttle from closing too quickly. The actual return spring is wrapped around the TB shaft.
MrKona |
Apr 21 2014, 11:59 AM
MrKona |
Apr 21 2014, 12:01 PM
ndfrigi |
Apr 21 2014, 01:29 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
type47 |
Apr 21 2014, 02:20 PM
What is the actual purpose of the long spring? It seems like it prevents the throttle from closing too quickly. probably makes it harder to push the gas pedal to prevent you from/make it a little harder to unleash all that HP (IMG:style_emoticons/default/rolleyes.gif) factory speed limiter? |
smarens |
Apr 21 2014, 03:36 PM
here is my '75 with 1.8, this is the way I got it, can't tell you for sure if this is correct/factory, 63k miles on it; good luck, please post what you find out
Attached thumbnail(s) |
Dave_Darling |
Apr 21 2014, 04:29 PM
What is the actual purpose of the long spring? It seems like it prevents the throttle from closing too quickly. The actual return spring is wrapped around the TB shaft. It's like the spring on the 2.0 throttle body--at least, all but the early 73s. The long coil spring is the primary return spring; the one coiled around the throttle shaft is the "supplemental return spring", and is intended to let the throttle close if the primary spring breaks. --DD |
jim_hoyland |
Jan 29 2017, 03:59 PM
Get that VIN ? Group: Members Posts: 9,317 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Found this thread while reattaching the return spring on my L-Jet; After looking at the picture I see mine had been on backwards; the outer end had been attached to the plenum instead of the rear tin.
When I connect the spring to the rear tin, it pulls the arm of the throttle body back Toward the rear. So, does this add tension to the main TB spring and make the accelerator pedal harder to push ? |
malcolm2 |
Jan 29 2017, 04:11 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I believe it is a safety thing. So if the big spring breaks the little one will close the TB.
I remember reading a post where someone actually did have the big spring break. He might be the only one alive (that did not die), (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) from not using the little spring. |
Shivers |
Jun 21 2023, 09:06 AM
Senior Member Group: Members Posts: 2,417 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Lo-Fi Version | Time is now: 5th June 2024 - 01:52 PM |
