> Upper Dash pad remove question, Upper dash pad remove question
jbchristie
post Apr 26 2014, 03:08 PM
I have found at least four bolts that are under the dash pad in the gas tank areaAttached Image
If I remove them can i pop the upper dash pad out
I loosened the first one in the picture and can move the pad
Not intested in removing glass or gas tank
Replies(1 - 6)
Bob L.
post Apr 26 2014, 06:12 PM
There are no dash pad screws in the front trunk. Those are to remove the metal dash frame.
There are nuts under the dash (inside) to remove the dash padding (the one with the crack in it). It's a pain in the butt knuckles. Once that is off you can remove the upper pad which is tucked into the lower-inner windshield seal. you need to remove the seal to get a new one in. I haven't done it but I've read it can be done without removing the windshield.
Do a search for dash pad removal. there are some good references with pic's of the nut locations.
Try this... http://www.914world.com/specs/Dash_Top_Removal.php
Good luck, and (IMG:style_emoticons/default/welcome.png)
Larmo63
post Apr 26 2014, 10:50 PM
I've never removed one, but this is very helpful for the future.
wes
post Apr 27 2014, 12:31 AM
wes
It's really not that bad, I pulled mine recently and seems that I had a bit of time finding the nuts on a few but read the thread if it's the same one you can't go wrong.
dlkawashima
post Apr 27 2014, 12:41 AM
pdlightning
post May 1 2014, 11:35 PM
Pdlightning
QUOTE(dlkawashima @ Apr 26 2014, 10:41 PM) *
Thanks for the great pics. All of your hard work makes it a lot easier for the rest of us.
GaroldShaffer
post May 2 2014, 07:00 AM
You bought another 914?
QUOTE(pdlightning @ May 2 2014, 12:35 AM) *
Don't for get there are 2 screws in the ashtray frame that do go into the dash a little bit. You really don't need to remove them, but I always do, sometimes the dash pad sticks to them.
Red Arrows point to there location.
- Lo-Fi Version Time is now: 2nd April 2026 - 06:00 PM
