My new favorite rust remover |
mepstein |
May 3 2014, 07:04 AM
914-6 GT in waiting Group: Members Posts: 19,305 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I soaked the fuse panel in vinegar for about an hour and wiped clean. Took off all the corrosion. The lug bolts were very rusty and soaked for a week. Hosed them off with no scrubbing required. They will never look new but certainly better than before. My wife hates the smell of solvents but couldn't care less about the smell of vinegar in the garage.
Attached thumbnail(s) Attached image(s) |
davep |
May 3 2014, 07:38 AM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
There are three common grades of vinegar; table, pickling, and cleaning in order of increasing strength. Acetic acid is not very strong, so it takes a while to do the job. Also very good as a vegetation killer; but you pay many times the price if you purchase it as a weed killer.
bulitt |
May 3 2014, 08:02 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
I wanted to test vinegar once as a cleaner. Threw some rusty bolt in a cup of vinegar and, well, forgot they were there (IMG:style_emoticons/default/biggrin.gif) . Found them several months later and all that was in the cup was about one inch of solid Iron Oxide. (IMG:style_emoticons/default/blink.gif)
speed metal army |
May 3 2014, 09:56 AM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
Oxcalic acid is pretty cool for removing rusty crap too. Sold as wood bleach at the hardware store..
Cap'n Krusty |
May 3 2014, 10:28 AM
I use "Evapo-Rust. Not too hard to find, I bought my last batch at HF. It treats the metal so surface rust is less likely to return. I have a 356 ring and pinion I treated several years ago, and it still looks fine.
The Cap'n |
Olympic 914 |
May 6 2014, 07:21 AM
Group: Members Posts: 1,672 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
+1 on evapo-rust
I used the vinegar method on an old roto-tiller fuel tank and was amazed at how good a job it did. left it for a couple days with a few nuts inside and shook it around periodically. .. Very clean inside and no damage. |
bulitt |
May 6 2014, 08:45 AM
(IMG:style_emoticons/default/agree.gif) Evapo-Rust works through a process called chelation where Vinegar being an acid sort of eats stuff away.
Al Meredith |
May 6 2014, 10:06 AM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
A friend who is restoring a Z car is using Molasses and H2O, 9 to 1, with great results. It takes a couple of weeks but only works on the rust , not paint or rubber.
AE354803 |
May 6 2014, 11:05 AM
Member Group: Members Posts: 232 Joined: 13-August 12 From: Southern California Member No.: 14,801 Region Association: Southern California |
I've had good success with citric acid. You can buy it powdered and mix it to whatever strength you want (saves on shipping and storage space). I think I got a 5 Lb bag on Amazon for less than $20. It smells like concentrated citrus and is sour as hell but it cleans really well and isn't strong enough to damage any metals I've used it on.
I've used 8 wt% to passivate some stainless parts and they made it through 4 weeks of salt spray testing with minimal corrosion only on welded areas, machined areas were fine. |
carr914 |
May 6 2014, 11:12 AM
Racer from Birth Group: Members Posts: 118,899 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
You can also use Baking Soda and Hydrogen Peroxide as a Paste
bulitt |
May 6 2014, 11:24 AM
You can also use Baking Soda and Hydrogen Peroxide as a Paste |
Drums66 |
May 6 2014, 11:39 AM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
I've had good success with citric acid. You can buy it powdered and mix it to whatever strength you want Ya.......I"m with this! (IMG:style_emoticons/default/thumb3d.gif) (IMG:style_emoticons/default/flag.gif) (IMG:style_emoticons/default/bye1.gif) |
Brian_Boss |
May 6 2014, 01:54 PM
Member Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 |
For parts small enough to soak, this stuff is magic. Try it and you will never mess around with home recipes again.
As someone alluded to, it doesn't attack steel at all so you don't have to worry about leaving the parts in too long and dissolving them. Also, no smell... I use "Evapo-Rust". Not too hard to find, I bought my last batch at HF. It treats the metal so surface rust is less likely to return. I have a 356 ring and pinion I treated several years ago, and it still looks fine. The Cap'n |
Lo-Fi Version | Time is now: 31st May 2024 - 07:27 PM |
