> How to support my car higher off the ground?, Without a lift and without fearing death
PanelBilly
post May 20 2014, 05:05 PM
I've been trying to figure out how I can support the car off the ground so its easier to work on. I was thinking of 30" or so. I've seen some tall jack stands, but they don't have a very wide base. There's no engine in the car, but hat and the tranny are the only part not installed. I was going to borrow a scissor jack, but it requires 230 and i only have 110 in the garage. any ideas? Blocks under the wheels?
3 Pages V  1 2 3 >
Replies(1 - 19)
wndsnd
post May 20 2014, 05:17 PM
You wanted a horse, but got a goat. Nobody wants a goat....
Always fear death ....
John
914forme
post May 20 2014, 05:32 PM
EZ-carlift several of us on the board have them, work great requires a drill to move it up and down.
Ezcarlift website
Its not cheap, but I hav gotten 5 years use out of mine, and it is stable, I feel safer around the car.
No experience with Quick Jacks by Ranger
arkitect
post May 20 2014, 05:35 PM
I've seen big jack stands on one of the threads, tried to do a Google search. No luck.
Try a search here to try to find the thread.
Dave
jmill
post May 20 2014, 06:01 PM
Green Hornet
QUOTE(PanelBilly @ May 20 2014, 06:05 PM) *
If it's your property and attached to the house, it's very easy to get 220 volts (actually 240) into the garage. Even easier if there is a subpanel in the garage. Might want to hire an electrician buddy if electricity scares you.
http://homerepair.about.com/od/electricalr...40v_breaker.htm
r_towle
post May 20 2014, 07:11 PM
Custom Member
look up JP Stein and his plywood boxes that go under the wheels
McMark
post May 20 2014, 07:16 PM
914 Freak!
Yup. JPs boxes kinda freak me out, but he used them for years and they work. Can't argue with success.
ripper911
post May 20 2014, 07:18 PM
corde pulsum tangite
(IMG:http://www.914world.com/bbs2/uploads_offsite/i921.photobucket.com-11654-1400635084.1.jpg)
I think my grandfather made these.
drive-ability
post May 20 2014, 07:28 PM
Harbor Freight has some tall heavy stands. I have a set and they are nice. 30" high. I still use a back up (IMG:style_emoticons/default/pray.gif)
914forme
post May 20 2014, 07:49 PM
Tons of people use wood. Somewhere I have a couple pictures of guys that built ramps out of wood, and then stored their 914s above other cars.
dlkawashima
no
(IMG:http://www.914world.com/bbs2/uploads_offsite/formationsecurite.ca-12234-1400636996.1.jpg)
Garland
post May 20 2014, 07:57 PM
Restoration Fanatic
Yes
Link:
Giant stands
r_towle
post May 20 2014, 08:01 PM
Custom Member
JPs boxes....
Very stable.
malcolm2
post May 20 2014, 08:11 PM
Isn't a dryer plug 230v? get a long dryer cord and borrow the lift. How long is the question.
Steve_R
post May 20 2014, 08:41 PM
I made this from some 4X4s and 4 casters.
You can even have Home Depot make all of the cuts and you just screw it together.
rick 918-S
post May 20 2014, 09:08 PM
Hey nice rack! -Celette
I thought I had a better photo of the stands I used under Ben's 6.
Steve
post May 20 2014, 09:51 PM
I love my Bendpak MD-6XP scissor lift. It runs on 110v and costs less than $2k
http://www.bendpak.com/car-lifts/specialty-lifts/md-6xp.aspx
stugray
post May 20 2014, 10:21 PM
Those plywood boxes are a safe bet if you have some skills with precision fit and some geometric smarts.
The stands that hold up giant fish tanks are made from plywood.
The 125 gallon tank in my living room is held up by what most of us would call "a bunch of 1X3s".
bulitt
post May 21 2014, 04:53 AM
Achtzylinder
Depends on your intended use?
Looking to raise up for one time major repair?
Looking to raise frequently for service?
Need to keep the wheels on?
Ok to remove wheels/suspension?
Then there is the lifting operation itself.
QUOTE(Steve_R @ May 20 2014, 10:41 PM) *
(IMG:http://www.914world.com/bbs2/uploads/post-14777-1400639955.jpg)
Lets you move the car around the garage. Make sure you install the large rubber caster wheels (as shown). I used the little ones at first and had ball bearings flying around the garage. (IMG:style_emoticons/default/blink.gif)
But can't really replace floor panels with this setup.
If you don't need to remove the tires cool setup. Stands would nest after use and not take up much space for storage. Lets you replace floor panels etc.
(IMG:http://www.914world.com/bbs2/uploads/post-43-1400641725_thumb.jpg)
carr914
post May 21 2014, 05:10 AM
Racer from Birth
Make some Box Cribs - easy & cheap. Don't use Pressurized Wood!
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 2nd April 2026 - 09:21 AM
