vibration in gas pedal |
RonnieJ |
May 24 2014, 02:34 PM
RonnieJ Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest |
I installed in a throttle cable and took it for a ride, I feel a vibration in the gas pedal that was never there before. Do you think I wrapped it around something? It isn't effected when I push in the clutch so I'm pretty sure it isn't around the clutch tube or cable.
Mike Bellis |
May 24 2014, 02:48 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
You might be feeling engine vibration. Check your rubber bits holding the motor.
Try to loosen the cable slightly. Just make sure you can get to WOT. This should reduce the vibration. |
Lo-Fi Version | Time is now: 9th June 2024 - 07:16 AM |
