Transaxle stack replacement?, Or do I need to change the entire transaxle? |
scott_in_nh |
Jun 4 2014, 07:52 AM
Senior Member Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
I bought a used transaxle that I am hoping shifts better than the one I have.
If it doesn't then at least I have a core to rebuild while the car is still on the road. Can I just lower the rear of the trans a bit and swap out the gear stack or am I looking at taking the entire transaxle out? Thanks, Scott |
dangrouche |
Jun 4 2014, 08:17 AM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
the tranny case can stay in place and you can remove the gear stack. drain the tranny, remove the gear stack; here are the instructions from Pelican Parts.
http://www.pelicanparts.com/techarticles/9...anny_repair.htm you may need the rear gasket for $5; get it from 914rubber.com, http://shop.914rubber.com/914-Transmission...sket-914TCG.htm or you can get the entire gasket set from Pelican |
toolguy |
Jun 4 2014, 08:42 AM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Can and should are two different things. .
the ring and pinion gears are a mated set. . At the least, you'd need to re-set the pinion depth [gaskets are shims] and that requires mandrels and dial indicators. . |
Dr Evil |
Jun 4 2014, 09:15 AM
You can not just swap the stacks. The pinion shaft and ring gear are a mated set and must not be interchanged. Your best bet would be to rebuild the core and swap it in whole. Then you can sell or rebuild the one in the car now and keep as a backup. |
messix |
Jun 5 2014, 11:25 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
dropping the tranny is not all that hard or time consuming
scott_in_nh |
Jun 6 2014, 06:42 AM
dropping the tranny is not all that hard or time consuming Agreed, it was just a thought that has now been put to rest. Thanks for the responses... (IMG:style_emoticons/default/beerchug.gif) |
rhcb914 |
Jun 6 2014, 06:39 PM
member Group: Members Posts: 358 Joined: 3-February 04 From: Boston, MA Member No.: 1,626 |
Rebuilding a tranny is pretty simple. Get the good DR's video it is excellent.
I also have the syncro removal tool, lineup jig and giant snap ring pliers if you need to borrow them, plus some spares from the 4 I pulled apart to make 2 good ones. |
r_towle |
Jun 6 2014, 06:44 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I also have a cut open transmission case that works very well for setting the shift rods...better than the jig.....
I also have air tools, space and the shop...(with spare parts trannies) if you want to do it.... Pull your stack, bring that and the new tranny.....we can make one that works well.. I will also leave you alone if you just need space to do it....no problem. |
r_towle |
Jun 6 2014, 06:46 PM
Oh, if need be, ride down and take my truck back for the parts.....
Rich |
scott_in_nh |
Jun 6 2014, 09:33 PM
thanks guys!
I'll let you know when I have a window to do it in. Rich I like the idea of pulling the stack and making one good one. (IMG:style_emoticons/default/laugh.gif) I have the Dr.'s DVD's I just haven't gotten around to watching them. (IMG:style_emoticons/default/wacko.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 07:09 PM |
