Brake fittings / size / DIN ? |
drive-ability |
Jun 5 2014, 07:14 PM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
To start with I have this but the adaptors are incorrect. They are for a standard flair fitting. I need the German style / double bubble ? What's it called ???
Second I'm using a Wilwood pedal box W/2 brake master cylinders and the brakes are Boxster front part number 996351426. There's some shots below, I don't know what size bore masters to use. Anyone have any thoughts ? (IMG:http://www.914world.com/bbs2/uploads_offsite/image.fourwheeler.com-3782-1402017286.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i987.photobucket.com-3782-1402017286.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i987.photobucket.com-3782-1402017286.3.jpg) |
bdstone914 |
Jun 5 2014, 07:29 PM
bdstone914 Group: Members Posts: 4,531 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Fitting size is 10 mm metric bubble flare. 914 standard master size is 17mm. 911 is 19mm.
Not sure 19 is even enough to operate the boxster calipers. |
infraredcalvin |
Jun 5 2014, 09:34 PM
Distracted Member Group: Members Posts: 1,523 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
I hope you're not planning to run stock 914 rears... Front/rear calipers should be upsized together, but that's another drawn out thread. That being said I did a later 930 upgrade to my early 930, swapped the 19mm with a Mercedes 23 mm unit, you might want to start there. You should really talk to these guys:
http://www.vehiclecraft.com/Brakes/930_upgrade.htm |
Dave_Darling |
Jun 5 2014, 10:07 PM
The whole point of dual master cylinders is so you do not have to run a proportioning valve. One M/C feeds the rear, the other feeds the front. You change the linkage between the pedal and the M/Cs to change the brake bias. No prop valve (or pressure limiting valve) needed.
--DD |
drive-ability |
Jun 6 2014, 12:21 AM
The whole point of dual master cylinders is so you do not have to run a proportioning valve. One M/C feeds the rear, the other feeds the front. You change the linkage between the pedal and the M/Cs to change the brake bias. No prop valve (or pressure limiting valve) needed. --DD (IMG:style_emoticons/default/confused24.gif) Shoot (IMG:style_emoticons/default/confused24.gif) I've got a lot to learn LOL I'll check out these guys. http://www.vehiclecraft.com/Brakes/930_upgrade.htm |
bulitt |
Jun 6 2014, 03:56 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
I hope you're not planning to run stock 914 rears... Front/rear calipers should be upsized together, but that's another drawn out thread. That being said I did a later 930 upgrade to my early 930, swapped the 19mm with a Mercedes 23 mm unit, you might want to start there. You should really talk to these guys: http://www.vehiclecraft.com/Brakes/930_upgrade.htm Wow, nice setup! But more than I paid for both 914's (IMG:style_emoticons/default/confused24.gif) |
drive-ability |
Jun 6 2014, 06:23 PM
I'm not running any stock parts on this car !!!! LOL I believe the brakes to be 996 / Boxster "S". OH, I'm running a stock TARGA top ! (IMG:style_emoticons/default/poke.gif)
Lo-Fi Version | Time is now: 2nd June 2024 - 01:59 AM |
