| swooshdave |
Jun 22 2014, 12:42 AM
Member ![]() ![]() Group: Members Posts: 184 Joined: 11-June 14 From: Portland Member No.: 17,475 Region Association: Pacific Northwest |
(IMG:http://www.914world.com/bbs2/uploads_offsite/i237.photobucket.com-17475-1403419333.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i237.photobucket.com-17475-1403419334.2.jpg) So is the what the underside of a bad hell hole looks like? |
| bulitt |
Jun 22 2014, 05:14 AM
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,189 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Problems usually start from battery acid.
So start looking from the battery down. The side panel the battery is welded to The engine shelf, engine mount and suspension console under the battery The area where these shelves attach to the rear firewall Then the acid continues to eat down through the long on the passenger side behind the jack plate. Do your doors close easily? are your door gaps equal? |
| jacksun |
Jun 22 2014, 07:03 AM
Member ![]() ![]() Group: Members Posts: 236 Joined: 8-August 13 From: mi Member No.: 16,224 Region Association: Upper MidWest |
hi,
I have just dropped the engine so I could deal with it out of the car. change heat exchangers, push rod tube seals, stuff like that. plus whatever comes up that I will discover. I need to do some hell hole welding too. seemed like it would be a lot easier to do the repairs without the engine in place. even using a flame thrower, the cheese head screw/bolts are no fun to remove. the ones that are tin to tin are not too bad.... the ones into the case take a lot more time with the flame thrower. I am learning as I go........mostly with the help of folks here helping me. have fun with the process........ I am randal |
| Allan |
Jun 22 2014, 08:25 AM
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Very repairable.
| mgp4591 |
Jun 22 2014, 08:45 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,037 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region
"You know where you are in a Hell Hole!"
Spinal Tap, 1984... (IMG:style_emoticons/default/aktion035.gif) |
| jmill |
Jun 22 2014, 08:50 AM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
| rhodyguy |
Jun 22 2014, 10:04 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
fugly.
| PanelBilly |
Jun 22 2014, 10:09 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,998 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
I'll give you a hand. Just let me know when you want to start.
| swooshdave |
Jun 22 2014, 10:20 AM
| swooshdave |
Jun 22 2014, 11:38 AM
(IMG:http://www.914world.com/bbs2/uploads_offsite/i237.photobucket.com-17475-1403458710.1.jpg)
Something sturdy must be holding the battery up. Not brave/foolish enough to pull the battery to look. Maybe some sort of anti-gravity device that will stop working if you look at it. Not worth the risk… |
| KELTY360 |
Jun 22 2014, 12:07 PM
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,192 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest
(IMG:http://www.914world.com/bbs2/uploads_offsite/i237.photobucket.com-17475-1403458710.1.jpg) Something sturdy must be holding the battery up. Not brave/foolish enough to pull the battery to look. Maybe some sort of anti-gravity device that will stop working if you look at it. Not worth the risk… You must go.....where no man has gone before. |
| cwpeden |
Jun 23 2014, 12:40 AM
Great White North, huh? ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
Looks like your engine is already half way out? Is this gap consistant all the way around?
| cary |
Jun 23 2014, 07:25 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest
Might be missing the seals. I didn't look yesterday.
Lo-Fi Version | Time is now: 4th October 2026 - 10:30 PM |
