jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,806 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
I used the iPad GPS to check my speedo. The faster the cars moving, the greater the error. For example in 5th @ 3K rpm speedo reads 5 under; at 3.4K in 5th speedo reads 15 under, etc
Low speeds under 50 are pretty accurate. Can this be corrected at a speedometer shop ? |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,192 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Yes, a good one can at least improve things. They'll probably change out the spring that returns the needle to 0; a stronger spring makes the gauge read less for a given speed, a weaker spring makes it read more.
--DD |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,889 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
Are you running stock tires? This can also effect your speedometer. North Hollywood Speedometer can adjust it.
Lo-Fi Version | Time is now: 3rd July 2025 - 02:03 AM |
