> while rebuilding a transmission..., the gear brake bands
rhodyguy
post Jul 2 2014, 11:06 AM
mostly mike, do you recommend doing those as well while i'm in there? i don't want to cheap out on the rebuild. once and done...
k
Replies(1 - 3)
McMark
post Jul 2 2014, 09:16 PM
914 Freak!
AKA Synchros.
Most of the time you can swap them fifth onto first, first onto fifth, second onto fourth, fourth onto second.
Or if the investment doesn't bother you, about $350-400 for new bands on 1-2-3.
Mark Henry
post Jul 3 2014, 10:19 AM
that's what I do!
They have a rough darker surface, if they have a polished ring around them they are done. Good used is fine.
Cap'n Krusty
post Jul 3 2014, 11:18 AM
Cap'n Krusty
"Brake bands" aren't "syncros" They're the little curved pieces that transfer pressure inside the syncro rings. If they're not beat up at the ends, they're probably OK. If you decide to change them, do 'em in pairs, and be sure you have the right style. Early components (the whole set of 4 pieces) differ from the improved later versions, and you CANNOT mix-n-match. First gear syncro internals are different from the 2/3/4/5 internals.
The Cap'n
- Lo-Fi Version Time is now: 15th April 2026 - 02:09 AM
