what is this, weep hole? |
jacksun |
Jul 21 2014, 07:48 AM
Member Group: Members Posts: 236 Joined: 8-August 13 From: mi Member No.: 16,224 Region Association: Upper MidWest |
hi,
I am wondering what the circled item is? when repairing the hell hole I have used "picklex" to convert the rust inside the longs,(minimal from what I can see) using a spray gun with an attachment hose that I purchased from a company online that sells a different product called "fluid film", a lanolin product. anyway,,, when I sprayed the rust converter with the spraygun/hose, some of the product dripped out of these holes that are original... are these holes, about five per side, meant to allow water to escape from the longs? also, it would seem that water could make it's way UP into the longs as well. thinking of caulking them? forgot the pic oops thanks randal |
Dave_Darling |
Jul 21 2014, 08:07 AM
Pic?
rhodyguy |
Jul 21 2014, 08:09 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
better pic? i can't figure out what you're trying to show.
doug_b_928 |
Jul 21 2014, 08:36 AM
Senior Member Group: Members Posts: 693 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
My assumption is that they are drains, but curious to see what the brain trust here says.
914GT |
Jul 21 2014, 08:52 AM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
Yes those are the drain holes. I would keep them open to prevent water entrapment inside the longs.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i216.photobucket.com-2923-1405954327.1.jpg) Guy |
Markl |
Jul 21 2014, 12:30 PM
Member Group: Members Posts: 75 Joined: 14-September 09 From: Colorado Member No.: 10,802 Region Association: Rocky Mountains |
One of my cars still has what appear to be factory plugs in those holes, but I've got to think that open would be better. Water getting in is is better than water staying in.
swooshdave |
Jul 21 2014, 01:39 PM
Member Group: Members Posts: 184 Joined: 11-June 14 From: Portland Member No.: 17,475 Region Association: Pacific Northwest |
SirAndy |
Jul 21 2014, 03:10 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
One of my cars still has what appear to be factory plugs in those holes, but I've got to think that open would be better. Water getting in is is better than water staying in. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/biggrin.gif) |
cary |
Jul 21 2014, 10:51 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
Dirt, undercoating, plus or minus 40 years .............
jacksun |
Jul 22 2014, 05:38 AM
hi,
if the hell hole is secure, meaning water tight, how could water enter the longs? also........ the cover plate that surrounds the jack slot has a weep hole also. how does water enter it other than through the hole? none of the pickle exited through that weep hole. both sides were filled with dirt and blocking those weep holes. and the dirt was not wet when cleaned out.. I cleaned it right after applying the picklex. tks randal |
doug_b_928 |
Jul 22 2014, 06:15 AM
On mine there appear to be entrance holes that look very similar to the ones on the bottom, but are a bit more open/rounded. They are located about an inch and a half forward from the firewall.
doug_b_928 |
Jul 22 2014, 06:16 AM
.....of course, these are on top of the inner longs.
bdstone914 |
Jul 22 2014, 07:20 AM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The longs are not air and water tight. They also added drain holes to the trailing arms. I have seen early trailing arms with no drain holes. Had them dip stripped and they came back with liquid inside. Heating and cooling of metal can cause condensation of moisture of the metal surface.
jacksun |
Jul 22 2014, 08:05 AM
tks bd....
now I understand |
zambezi |
Jul 22 2014, 11:02 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
Yes I agree with Bruce. If the heater gets used then the longitudinal will get warm. The cold outside air will let moisture condense on both inside and outside of the sheetmetal. The water needs a place to get out or it will rust even faster than it already does.
swooshdave |
Jul 22 2014, 11:06 PM
But, but someone told me there couldn't be any condensation inside the longs because they used paper tubes…
zambezi |
Jul 22 2014, 11:17 PM
They do use paper tubes, but not for the entire length. The purpose of the paper tubes is they act as a noise muffler. The 356C's were the first to start using the paper section in the middle of the heater tubes. Still gonna get hot in there.
Lo-Fi Version | Time is now: 10th June 2024 - 04:57 AM |
