Correct Rack? |
Correct Rack? |
MikeM |
Aug 2 2014, 04:24 PM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all....I'm doing a turbo tie rod installation, and since there seemed to be some play in my steering rack, I purchased a used one from Bruce Stone.
Bruce sent me a ZF rack that is slightly different than the one that came out of my car. The one that was in the car has a 914 number on it, the other has a ZF number on it. The car is a '74 914. Number is 914 347 014 01. Number on the ZF rack is 7820 955 112. I'm pretty sure this rack will work in my car, as is Bruce Stone. Just want to be absolutely certain before I do the installation. Thanks as always, Mike |
MikeM |
Aug 3 2014, 07:41 AM
BUMP!!!
JFJ914 |
Aug 3 2014, 06:56 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
The ZF rack is probably out of a 911. Just check the dimensions. It might require different mounting bolts, early 914's had the threads higher in the mounting bosses and used longer bolts. Make sure you use the 914 input shaft, it's longer than the 911 one.
Lo-Fi Version | Time is now: 1st June 2024 - 08:44 AM |
