partwerks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 ![]() |
I'm wondering if I even need that klunky old termite pedal board if I am going to a hydraulic CMC, and drive by wire technique??
I'm guessing the travel on the CMC would be similar to how the brake pedal travels, and would not need that clutch stop bracket, as one does with the cable anymore. I certainly won't need that stop for the foot feed. |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,545 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
What is CMC?
partwerks |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,514 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
The carpet is cut to fit that board. Your adjustable accelerator stop is on that board also. The stock pedal will give you a little over 1" travel which is plenty for that Wilwood.
partwerks |
Sounds like I would need it for the carpet only. DBW won't need the accelerator stop then.
Lo-Fi Version | Time is now: 18th June 2024 - 09:10 AM |
