Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
More newbie questions: Are there any differences between a 1.7 and a 2.0 901 style 914 transmission? Also, since 914 transmissions are stamped VW, were they made in a separate factory different than where the "real" 901/911/912 Porsche transmissions were made? I assume Porsche didn't have the capacity to manufacture 25,000+ transmissions at their factory?
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,100 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
More newbie questions: Are there any differences between a 1.7 and a 2.0 901 style 914 transmission? Also, since 914 transmissions are stamped VW, were they made in a separate factory different than where the "real" 901/911/912 Porsche transmissions were made? I assume Porsche didn't have the capacity to manufacture 25,000+ transmissions at their factory? Difference was not between engine size, but early and late. Pre 73 cars were "tail shifters" 73+ were "side shifters" a rare few had factory LSDs. 6's had their own transmission as well. |
Bruce Hinds |
V-8 madness ![]() ![]() ![]() Group: Members Posts: 748 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest ![]() |
What was different about the -6 transaxles other than being an early tail shifter . . .
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,031 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Larmo63 |
So, what about the "VW" stamping on the case?
Jon B |
Member ![]() ![]() Group: Members Posts: 73 Joined: 28-September 13 From: Vista, CA Member No.: 16,448 Region Association: None ![]() |
What was different about the -6 transaxles other than being an early tail shifter . . . Bruce Also larger axle flanges, and IP-mounted bellcrank for Weber carb linkage. Jon B. |
Jon B |
So, what about the "VW" stamping on the case? Volkswagen produced transmission cases for 914/4 models, also manufactured the gears, all to Porsche design specs. Case pieces for 914/6 models were produced by regular Porsche suppliers Honsel and Mahle. Jon B. Vista, CA |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Earlier boxes also tend to have writing on the gears, like their Porsche purebred brethren. You will find that 911/912 gears have different stampings and hand written numbers to match the gears. You can see this in very early tail shifters. I have a few 1st gears with "Ghia" written on them. The stampings are different for all the 914 gears compared to 911/912 which makes identifying by lay people a bit difficult. The problem lies in the alpha alpha system they used in manufacture; You will have a V gear, but it will also have a random W or something else stamped on it. That will mean W run of V gear. No idea whey they didnt do numeric or some other way.
Other differences are the holes in the bell housing that were round on older cases and square on newer. The bands and blocks inside the synchro bands on the tails shifters are different sizes than the ones in a side shifter. Almost all of the tail shifters had a boss for the bell crank for the throttle linkage. Newer ones can be found missing this. That is all off of the top of my head. |
Lo-Fi Version | Time is now: 6th July 2025 - 04:07 PM |
