Valve guide dimension wanted, A stock 1,7 with new guides |
larss |
Sep 26 2014, 08:14 AM
Member Group: Members Posts: 428 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia |
For a stock 1,7 with new valve guides is there a known inner dia specification?
Or lets say the valve stem is 7,95mm is there a clearance to the inner dia of the guide to aim for? Looking for recommendation on both inlet and outlet valve guides. Thanks /Lars S |
pilothyer |
Sep 26 2014, 09:03 AM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
For a stock 1,7 with new valve guides is there a known inner dia specification? Or lets say the valve stem is 7,95mm is there a clearance to the inner dia of the guide to aim for? Looking for recommendation on both inlet and outlet valve guides. Thanks /Lars S The factory specs for the intake valve stem OD is 7.94 to 7.95 with the valve guide ID being 8.00 to 8.02 with a wear limit of 8.06. The exhaust valve stem OD is 8.91 to 8.92 with the guide ID of 9.00 to 9.02 with a wear limit of 9.06. You want the stem to fit in such a way as to allow no tipping |
larss |
Sep 26 2014, 11:21 AM
Many thanks Pilothyer!
/Lars S |
Lo-Fi Version | Time is now: 7th June 2024 - 02:03 PM |
