cutting out shelf in enegine bay, on the forward fire wall |
scotty914 |
Jan 27 2005, 08:48 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
okay from what i remember the shelf the the engine seal sits on, is two pieces welded at the back edge. i want to cut it out for air flow reasons ( radiator ), is it welded at the firewall or should i weld it after i cut it. there is a great pic of joe's 914rs ( stole pic below ) where he cut out the shelf.
Attached image(s) |
bondo |
Jan 27 2005, 09:08 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
It is at a seam between 2 different parts of the firewall. If there were no engine shelf there would still be a lip. The shelf is spotwelded to that. If you cut at the right place you will only have to cut 1 layer of metal.. go too far towards the firewall and you'll have to cut three. If you go wayy too far towards the firewall, your car may fall apart. (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif)
Lo-Fi Version | Time is now: 7th June 2024 - 01:57 PM |
