> 914/6 Ignition Switch
McMark
post Oct 12 2014, 02:16 PM
914 Freak!
I've been collecting parts for my conversion and I just got my 911 ignition switch (P/N 911.613.011.01). It's got the correct silver center. I have an original 914/6 steering column, but the steering lock arm doesn't fit into the bracket into the column. I know this is a 'normal' thing and removing some material will make everything work fine. But since I'm mostly insane, I'd like to see pics of a real 914/6 ignition switch to compare and replicate if possible.
Anyone have pictures?
Even better, anyone have one they can measure?
And what about the original unit part number? What's that? The number in the PET doesn't seem to match the numbers I've seen.
Replies(1 - 19)
post Oct 12 2014, 03:51 PM
Resident German
Yepp, i had to shave off some material from the 911 switch i used.
(IMG:style_emoticons/default/smash.gif)
SixerJ
post Oct 12 2014, 03:56 PM
Region Association: England
Hi Mark, does this help?
I bought a complete -6 lock set (or at least that's what it was advertised as) of the bay about a year ago - Sir Andy?
Let me know if you need more pictures
Jon
SixerJ
post Oct 12 2014, 04:01 PM
Last 2 pictures, the last one was a bit difficult to take in situ
5mm recess measurement is when viewed from the front of the lock
McMark
post Oct 12 2014, 04:08 PM
914 Freak!
SixerJ, THANKS! Can you take one more with the part number facing down?
SixerJ
post Oct 12 2014, 04:23 PM
QUOTE(McMark @ Oct 12 2014, 11:08 PM) *
Here you go, should have thought about it in the 1st place
sixnotfour
post Oct 12 2014, 07:17 PM
they added more material so the bolt actually secured the lock in position = hareder to remove... grind flat = done
914Sixer
post Oct 12 2014, 09:24 PM
914-6 PET shows the lock assembly as 911.613.901.00. So the one you are using is a later one. There was one assembly for the 65-68 911 column, one for the 69-73 911 column and then 74-89.
McMark
post Oct 12 2014, 09:34 PM
914 Freak!
Awesome! Now I can make mine look right.
QUOTE(sixnotfour @ Oct 12 2014, 06:17 PM) *
grind flat = done
You make it sound so easy. If only it was for the obsessive compulsive. (IMG:style_emoticons/default/unsure.gif)
SixerJ
post Oct 13 2014, 09:09 AM
Mark,
Apologies for hijacking your thread, but could you take some detailed pictures of your genuine column with any relevant dimensions for the flat bracket position on the tube factory welding details, any other relevant dimensional information etc?
I was thinking it would be useful to capture details of both the ignition lock and column in a single thread for those who we're thinking of building themselves a facsimile of the factory set up?
Also those in the know regarding the exact differences (functionality of the switch and connectors) between the 911 switches and 914-6 would be useful to capture in a single place as well
larryM
post Oct 16 2014, 09:21 PM
emoze
notwithstanding all the perfection above
- if you are going to track the car with any of the sanctioned race clubs - (my experience per scca & vara) - it is generally required to disable ( remove or block) that interlock mechanism
nobody wants a non-steerable missile coming down the track at them
McMark
post Oct 21 2014, 12:21 PM
914 Freak!
Pictures of the steering column. Let me know what else you need.
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
Mark Henry
post Oct 21 2014, 01:01 PM
that's what I do!
This is a lot of work...wasn't the '72 six just like a /4 with the key on the column?
Just asking because I don't need any help fueling my OCD on this point for my '74 /6 conversion. (IMG:style_emoticons/default/wink.gif)
post Oct 21 2014, 03:34 PM
914-6 GT in waiting
QUOTE(Mark Henry @ Oct 21 2014, 03:01 PM) *
It is work and money. It's optional but if you like the look, go for it.
biosurfer1
post Oct 21 2014, 03:40 PM
Teener fo Life!
QUOTE(McMark @ Oct 12 2014, 08:34 PM) *
grind flat, throw away, grind flat, throw away, grind flat, throw away, grind flat = done
There, fixed it (IMG:style_emoticons/default/smile.gif)
altitude411
post Oct 21 2014, 04:32 PM
I drove my 6 into a tree
Attached ImageWhat is this connection for? My '70 six does not have it...
Also does any know of a clamshell vendor or have one for sale? Mine would be repairable (epoxy/fiberglass/paint) but I would replace if possible.
type47fan
post Oct 21 2014, 07:28 PM
It Looks Better In Person. . .
QUOTE(altitude411 @ Oct 21 2014, 03:32 PM) *
. . . 911 "key in ignition" buzzer alert?
altitude411
post Oct 21 2014, 07:54 PM
Ah, that makes sense. Good, I'm glad I don't have one! I hate those things. They always scare away the deer when I'm poach, er.... um, hunting. (IMG:style_emoticons/default/ar15.gif)
McMark
post Oct 21 2014, 08:08 PM
914 Freak!
DON'T buy the reproduction from Automobile Atlanta. It's a terrible 'reproduction' (if you can even call it that). (IMG:style_emoticons/default/sad.gif)
altitude411
post Oct 21 2014, 08:21 PM
Thanks for the heads up Mark, I'll keep shopping the e. (IMG:style_emoticons/default/popcorn[1].gif)
- Lo-Fi Version Time is now: 12th November 2025 - 07:12 AM
