WTB: Back-Up Light Switch |
rmital |
Oct 24 2014, 07:37 AM
Northeast optimist Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
looking for a good back-up light switch.
914-613-541-02 I think they are available new from Pelican, but looking to save some cash since for project car. thanks, Ray |
914Sixer |
Oct 25 2014, 07:34 AM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
URO is making reproductions in the $30 range.
pilothyer |
Oct 25 2014, 09:05 AM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Ray,
Is yours missing or not working...if it's not working it usually turns out to be the pin that wears out and just gets too short.............the switch rarely fails...easy to test with ohm meter after you take it out. |
bdstone914 |
Oct 25 2014, 12:01 PM
bdstone914 Group: Members Posts: 4,534 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have a couple of used switches that need the ceramic repaired. Both tested and work.
Also have a pin. It could be you need either or both. I recently had to replace both on a trans. I would want $20 for a switch. Attached thumbnail(s) |
rmital |
Oct 27 2014, 06:51 AM
Ray, Is yours missing or not working...if it's not working it usually turns out to be the pin that wears out and just gets too short.............the switch rarely fails...easy to test with ohm meter after you take it out. after dropping the engine...checking all connections and bits and pieces, the switch looked a little beat up. The ceramic was chewed up. I figure it would a good time to replace. it was in working condition, just not very pretty.... (IMG:style_emoticons/default/biggrin.gif) I will test it though now that it has been roughened up before I button everything back up. |
rmital |
Oct 27 2014, 06:53 AM
I have a couple of used switches that need the ceramic repaired. Both tested and work. Also have a pin. It could be you need either or both. I recently had to replace both on a trans. I would want $20 for a switch. those look like the one I'm looking to replace. if I test and it's not in working condition, I'll get back to you. Thanks! |
Lo-Fi Version | Time is now: 4th June 2024 - 08:09 PM |
