| 913B |
Oct 31 2014, 06:15 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 869 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
From the last time I tried with the engine running and spraying carb cleaner everywhere and causing a big mess. I did not really see a big RPM difference, maybe I was doing it wrong, maybe I was expecting too big a change and moved on too quickly, but nothing really came from it. I still suffer from a periodic hi idle (1500 rpm), sometimes it idles fine at 800. If it was a vacuum leak why did it correct itself and sometimes idle at 800 ? I have since removed the AAR and even swapped out the MPS with another one, no difference. Stock 1.7 FI
So the discussion for today is what is the proper method, tips and tricks to perform a good vacuum leak check. I am tempted to make a DIY homemade smoke machine from watching youtube to blow smoke in my FI system and check it that way ?? Thoughts (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) |
| 02loftsmoor |
Oct 31 2014, 06:25 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region
From the last time I tried with the engine running and spraying carb cleaner everywhere and causing a big mess. I did not really see a big RPM difference, maybe I was doing it wrong, maybe I was expecting too big a change and moved on too quickly, but nothing really came from it. I still suffer from a periodic hi idle (1500 rpm), sometimes it idles fine at 800. If it was a vacuum leak why did it correct itself and sometimes idle at 800 ? I have since removed the AAR and even swapped out the MPS with another one, no difference. Stock 1.7 FI So the discussion for today is what is the proper method, tips and tricks to perform a good vacuum leak check. I am tempted to make a DIY homemade smoke machine from watching youtube to blow smoke in my FI system and check it that way ?? Thoughts (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) your going to make a mess, but oil out of your oil can works well |
| bdstone914 |
Oct 31 2014, 06:47 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,295 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have not tried it but using a non lite propane torch. When it sucks in the propane the idle should increase.
| 76-914 |
Oct 31 2014, 07:03 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,880 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
or a spray with water and look for an idle drop.
| 913B |
Oct 31 2014, 07:46 PM
I was thinking of something similiar to this with either a charcoal or just a cigar, something cheap and simple in a empty/clean metal paint can ?
https://www.youtube.com/watch?v=FFlyAqiYMro |
| JeffBowlsby |
Oct 31 2014, 08:35 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,246 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
How a bout a smoke pen? a vacuum leak would visibly suck the smoke into the leak location, no fuss no muss.
Here is one: http://www.toolexperts.com/smoke-pen-penci...s-air-flow.html |
| Chris Pincetich |
Oct 31 2014, 11:08 PM
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
| a few loose screws |
Nov 1 2014, 03:57 AM
Member ![]() ![]() Group: Members Posts: 168 Joined: 8-August 14 From: canada Member No.: 17,754 Region Association: None |
As far as the combustible methods go, personally I'd go with the unlit propane torch. You could also try another way, and that is to use your ears. I'm not being being a smart ass. I know its almost impossible to get your head in to even a spacious engine bay. Use a length of rubber hose, hold one end to your ear and probe around all the usual places where vacuum leaks occur. You can feed the hose right in to the tightest spots too. The nice thing about this is you can cup your hand over vacuum fittings, lines, mating areas on intakes, or carb bodies, if you have carbs, and amplify the sound of even a small leak. Once found, use your fingers to bock the leak. Now you know exactly where your leak is.
| cary |
Nov 1 2014, 08:52 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest
I built a smoke generator out of a paint bucket. It was built to find a manifold leak on a 4.0 Ford explorer. Basically you light a rag soaked with WD40 to create the smoke. Put the lid on it and push the smoke into the intake with air pressure. Found the leaking seal in about 30 seconds.
You got me thinking what air pressure did I use. I'll have to see if I wrote it on the top of the can. I'll shoot a picture of it today. I have a long hose attached to a torch nozzle too. I can never get that test to work. My .02c. |
| r_towle |
Nov 1 2014, 08:54 AM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Go back to the issue.
A periodic high idle , in my opinion, is not a vacuum leak. I would look at cleaning your distributor advance plates and regreasing them. |
| EdwardBlume |
Nov 1 2014, 09:00 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
Go back to the issue. A periodic high idle , in my opinion, is not a vacuum leak. I would look at cleaning your distributor advance plates and regreasing them. (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) I have this problem. Idle pops up to 1200 or so occasionally and intermittently. |
| 913B |
Nov 1 2014, 11:51 AM
I built a smoke generator out of a paint bucket. It was built to find a manifold leak on a 4.0 Ford explorer. Basically you light a rag soaked with WD40 to create the smoke. Put the lid on it and push the smoke into the intake with air pressure. Found the leaking seal in about 30 seconds. You got me thinking what air pressure did I use. I'll have to see if I wrote it on the top of the can. I'll shoot a picture of it today. I have a long hose attached to a torch nozzle too. I can never get that test to work. My .02c. I was going to attach a tire pump to the can like the video, would that be too high of pressure ? Thanks for the pic |
| 913B |
Nov 1 2014, 11:54 AM
Go back to the issue. A periodic high idle , in my opinion, is not a vacuum leak. I would look at cleaning your distributor advance plates and regreasing them. Yeah I did that too, completely removed and rebuilt the distributor, unless i didnt greased it enough, it did move when I used my mity-vac on it ? (IMG:style_emoticons/default/confused24.gif) Maybe a different sensor then CHT or IAT confusing the ecm ? |
| boxsterfan |
Nov 1 2014, 11:16 PM
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
My idle problems went away with a new CHT and spacer. 1974 2.0L.
| 913B |
Nov 2 2014, 12:11 AM
whats the spacer ?
| Porschef |
Nov 2 2014, 05:10 AM
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,180 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States
An adapter essentially that goes between the CHT sensor and the block. Delays heating of the sensor as to trick the ECU into thinking the engine is cooler than it really is, thus keeping the mixture richer longer.
Brad Mayeur sells them. I made one but it didn't seem to help (IMG:style_emoticons/default/dry.gif) |
| BeatNavy |
Nov 2 2014, 05:30 AM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,962 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
My idle problems went away with a new CHT and spacer. 1974 2.0L. I like the spacer, too. It really helped warm-up by preventing engine from going too lean. But I'm not sure this will help stabilize idle, particularly after warm-up. Based on what else you've tried I'd think about the dizzy like Rich suggests. |
Lo-Fi Version | Time is now: 2nd May 2026 - 05:29 AM |
